Tools???
#17
I like the protek ones but they are a little pricy, if you want to go cheap the dynamite ones are a pretty good deal.
#18
Here are the fake Hudy Ultimate Body Scissors. Again, the package only had one staple instead of four like it should. I was able to slide them out of the package and inspect both sides. They felt heavy and there was no Hudy logo.
I quickly snapped a pic before sending them back; my bad for the glare.
#19
Here is the real McCoy. Check the Hudy logo.
#20
Droop and Ride Height.
1. Can I use the same tool to measure droop and ride height on 1/8 and 1/10 buggies?
2. Who knows where zero droop is anyway?
Is the height of the blocks that go under the chassis equal to zero droop?
3. What good is a 17-30mm Hudy ride height kit when all my buggies have more than 30mm ground clearance? what am I missing?
http://www.hudy.net/xhudy/products/p...3&kategoria=64
#21
Ride height is ground clearance when you set the vehicle to sit on the suspension on a flat surface.
Droop height is ground clearance when the suspension is fully uncompressed.
Most people measure "droop" by going eyelet to eyelet on the shock. I personally like the method of measuring droop by lifting the car until the wheels leave the table and measuring that height. Both are correct, but you can't match a setup sheet that uses one method by using the other.
For racing, most ride heights will be in the 20-25mm range off road (slightly more in 8th scale). Carpet will be even less than that, and on road goes around 5mm.
#22
I have just about everything except set up tools. I even got the Arrowmax shock pliers. They are nice.
Question. Is the Losi shock matching tool useful?
#23
#24
Nobody ever mentioned a Dremel. I cant count how many times a dremel has helped me to remove stripped screws heads, and make custom modifications. It is one of the most valuable tools in my box.
#26
Yes, I completely agree, quality tools are a good investment. I have more than enough tools than I really need. I was just saying that the dremel is perfectly suited for modding ventures, which I do quite frequently.
#27
