Power Supply?
Old 03-17-2013 | 03:11 PM
  #16
Hoese37's Avatar
Originally Posted by XRated SCT
80$ isn't a issue for me after I've already put down over 1200$ for my new setup and it has enough amps and wattage to supply for what I'm charging, IMO I'd buy a new supply rather than a used pc supply, I do agree max amps is overpriced but the supply I don't have a problem w/
Yeah, online we all have unlimited budgets...
Hoese37 is offline
Old 03-17-2013 | 04:55 PM
  #17
Arr double post.
Dave H is offline
Old 03-17-2013 | 05:00 PM
  #18
Are you sure the MA supply is new? I thought new ones like that were fairly expensive? Seem to remember reading a thread that Brandon of MA was posting in where this was asked but I don't recall Brandon providing an answer.
Originally Posted by Johnnysplits
They don't have to stay raw aluminum...
How would you describe the fan noise on those puppies? Continuous run, variable speed, etc? (I've found some server supplies to be rather obnoxious)
Dave H is offline
Old 03-17-2013 | 06:05 PM
  #19
The fan noise is quite low. The fan I use in the garage makes more noise.
Johnnysplits is offline
Old 03-18-2013 | 10:18 AM
  #20
Check out my post Here on RCTech about this very same issue.
Don't buy a 46A Power Supply for $80 when you can build yourself a 100A for less then $40.
WindDrake is offline
