RB Engine Thread
#422
Does anyone know another choice for exhaust pipe and header for rb t9 Murnan modified seems that most hobby shop are out of the 2668 rb exhaust .I was told that the reds exhaust pipe and header would work 2669. Please can I get some feedback thanks.
#423
The novarossi 2660 with 41016 header works very well.
#424
#425
Fellas quick question, for you motor gurus, Can I run 20% thru my RB T11 rc in stock form? Or do i have to add a shim to the head? im in the bay Area 70-100 degrees....If I do run 20% what are signs that would say add a shim!!
#426
Here's another, is it possible to add a shim to the head to gain runtime?
#427
#428
#429
You dont have to add the shim, but it will allow you to lean the engine more. It is also easier on glowplugs to add the shim.
#430
hay guys just wonting to know is the tXr really worth the extra $100 or is the TX good enough as iam looking to buy 2 engines at once. i see amain have them in the combo but to buy the txr in the combo it means the pipe is like $80 more.
so realy i would like to know if i would regret buying the tx cause the txr is that much better? i currently run a nova keep on so wich ever is the closest to that
#431
#432
#434
1Likes
