SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 03-04-2013 | 01:38 PM
  #3091
xrayrc's Avatar
can anyone shed some light on how to get the body mounts to work with the sc10b front shock tower?
xrayrc is offline
Old 03-04-2013 | 01:50 PM
  #3092
easye's Avatar
Hold it up to the tower and drill the new shock holes in the body mount.
easye is offline
Old 03-04-2013 | 04:20 PM
  #3093
Default 550 can
I have a factory team sc10 with a novak pro sc and the ballistic 550 can 4.5 Is this a good combo or should I go to the 540 can motors. Didn't know if anyone has tried both these setups and could give me some pointers.
scott74dog is offline
Old 03-04-2013 | 04:25 PM
  #3094
easye's Avatar
No 550 can 4.5 in a 2wd sc somthing like a 8.5 turn 540 can.
easye is offline
Old 03-04-2013 | 04:31 PM
  #3095
mxracer458's Avatar
550 is meant for 4wd cars,the motor is long and will hang out plus the shaft is 5mm right? just stick with 540 size motors,they are meant for 19th scale
mxracer458 is offline
Old 03-05-2013 | 03:25 PM
  #3096
platgof's Avatar
SC10B I drilled the outside holes to mount the post, and dremeled the inside of the post to fit the shocks. I marked the center post hole with a sharpie before drilling it. You will probably need a nut on the center post hole and outboard ones.
platgof is offline
Old 03-06-2013 | 08:12 AM
  #3097
Picked up a second SC10 tonight.. Trying to decide whether to have it as a spare/one for the kids (along with the blitz) or turn it into an SC10B.
Chamelion is offline
Old 03-06-2013 | 08:42 AM
  #3098
I plan on converting mine over to an sc10b if ae would ever release/announce the much rumored sc10.1 or .2 or whatever it is called
ritojr is offline
Old 03-06-2013 | 08:45 AM
  #3099
Wildcat1971's Avatar
Tech Prophet
I plan to convert my sc10 to sc10b as soon as the arms become more available.
Wildcat1971 is offline
Old 03-06-2013 | 04:31 PM
  #3100
what does it take to make it an sc10b. i got an extra chassie or do you need all the crap. they use all the same parts almost or what
imrob is offline
Old 03-06-2013 | 04:36 PM
  #3101
Tech Prophet
front and read bumps, front tower and arms, body and roll cage. ebay is best for the parts
Old 03-08-2013 | 09:32 AM
  #3102
mxracer458's Avatar
Anyone running the +3 wheels with the stock sc body?if so do the tires clear the outside if the fender?i know now with the standard wheels its close
Old 03-08-2013 | 12:45 PM
  #3103
Default Do these caster blocks work for SC10?
http://www.teamassociated.com/parts/details/7922/
shagnat is offline
Old 03-08-2013 | 12:46 PM
  #3104
Lance Tanner's Avatar
Couldn't figure out how to PM these, no paperclip to attach. These first two I saved off this thread before I did the swap and can't remember exactly who the two 'owner's of these pics are.
Attached Thumbnails SC10 Thread Part 2-scb-tower-sc10.jpg   SC10 Thread Part 2-scb-tower-sc10-another-pic.jpg
Lance Tanner is offline
Old 03-08-2013 | 12:52 PM
  #3105
Front/top/rear shots of mine. Just a little dremmel work on the body mount itself and new (had to be taller) body posts-I even lucked into the posts/holes lining back up perfectly
Next post has 3rd pic, would only allow me to post 2.
Attached Thumbnails SC10 Thread Part 2-lance1.jpg   SC10 Thread Part 2-lance2.jpg
