SC10 Thread Part 2
#3094
No 550 can 4.5 in a 2wd sc somthing like a 8.5 turn 540 can.
#3095
550 is meant for 4wd cars,the motor is long and will hang out plus the shaft is 5mm right? just stick with 540 size motors,they are meant for 19th scale
#3096
SC10B I drilled the outside holes to mount the post, and dremeled the inside of the post to fit the shocks. I marked the center post hole with a sharpie before drilling it. You will probably need a nut on the center post hole and outboard ones.
#3104
Couldn't figure out how to PM these, no paperclip to attach. These first two I saved off this thread before I did the swap and can't remember exactly who the two 'owner's of these pics are.
#3105
Front/top/rear shots of mine. Just a little dremmel work on the body mount itself and new (had to be taller) body posts-I even lucked into the posts/holes lining back up perfectly
Next post has 3rd pic, would only allow me to post 2.
24Likes
