Like Tree3Likes
Mugen MBX6
Old 03-11-2013 | 04:52 PM
  #18271
Originally Posted by DLF
For those of you who have a MBX6R, or have the E0185 aluminum rear arm mount, have you guys figured out the combinations for the inserts? You get three: A, B and C. Looking at the diagrams, it tells you what combinations gets you what, but it doesn't really specify the letter of the insert. Inserts A and B could be the same. Only the C insert with the notch in the middle can't be confused with the others.
Am I missing something obvious?
What was the answer to this question? I searched and didn't find how to setup the inserts.
djs101 is offline
Old 03-11-2013 | 10:15 PM
  #18272
shajohan's Avatar
just finish swapping complete MBX7 drivetrain in my 6...
interchangble MBX7 parts involve
3 pcs E2201 DIFF CASE
2 pcs E2202 CONICAL GEAR Front/Rear
2 pcs E2204 BEVEL GEAR Front/Rear
1 E2206 GEAR SPUR
will post sum photo soon...
shajohan is offline
Old 03-12-2013 | 12:56 AM
  #18273
mxr17's Avatar
A and B are in fact same inserts, it's just the way you install them that makes the adjustments, I don't have the instruction with me now to say what position does what.
mxr17 is offline
Old 03-12-2013 | 07:09 AM
  #18274
Originally Posted by mxr17
I use the fioroni and in it you can put whatever engine, I have spare engine mounts on 3 engines ( nova P4, OS,Alpha ) and all fit perfect.
I have a personal idea of what should be customer service and when I send an email to a shop or a brand and they feel like not answering, I then feel like not giving them my hard earned money.
well said man, and thanks a lot for the heads up.
1 E2206 GEAR SPUR
awaiting your photos and feed back on how much it improves the handling of the x6, thanks a ton for sharing
basher88 is offline
Old 03-13-2013 | 02:22 AM
  #18275
shajohan's Avatar
Default mbx6 swap mbx7 drivetrain
centre diff........................
Front Rear.............................................. .
helical vs straight cut gear
mbx6 diff gear set fit well inside mbx7 diffcase
also fit well inside gearbox case without any modification...
before. mbx6
after. mbx7
Gain some improvement but not too much... character and feeling also change a bit...
Quicker acceleration smoother entering and exit the corner...
Fuel Run-time - Not testing yet..
shajohan is offline
Old 03-13-2013 | 02:52 AM
  #18276
shajohan, nice work man, thanks a lot for sharing, please tell us more about the upgrade, i've heard lots of good things with the x7's handling, and if the gearing contributes most of the improvements over the x6, then what you've been doing might save a lot of cash for the x7 just for better performances. And of course i'll also go this route for a smaller budget(cuz i don't have the budget for the x7, hehe).
basher88 is offline
Old 03-13-2013 | 03:32 AM
  #18277
sschultz's Avatar
Originally Posted by got_nitro
I'm not sure about your question but if you have BOTH cars why don't you check and tell us?
Thank you...
I needed a good Wednesday knee slapper...
sschultz is offline
Old 03-13-2013 | 04:44 AM
  #18278
morgoth's Avatar
Why don't you sell the X6 and get the X7. It's cheaper than upgrades all those parts.
morgoth is offline
Old 03-13-2013 | 05:57 AM
  #18279
shajohan's Avatar
True...
Experimenting with new stuff and understanding how does its works is really exciting.
shajohan is offline
Old 03-13-2013 | 06:43 AM
  #18280
shajohan's Avatar
Case+bevel+conical = $ 58.00 -+
or
complete one diff set with only $55.99.. spare when u already owned a mbx7 with different diff oil setup...
http://www.amainhobbies.com/product_info.php/cPath/1_25_1480_2801/products_id/246369/n/Mugen-Complete-Front-Rear-Differential-Set[
there are lots factor makes mbx7 is a good car..
suspension geometry n design
steering geometry
wider chassis
drive train
and lot's more....
shajohan is offline
Old 03-13-2013 | 07:05 AM
  #18281
or
steering geometry
wider chassis
drive train
and lot's more....
Thanks a ton for the heads up man, hey that amain complete set price is not bad, only need the center diff set to complete the drive train. But you may be right there're lots of factors for the good handling of the x7, i'll think about it.....hehe
basher88 is offline
Old 03-13-2013 | 03:24 PM
  #18282
Anything wrong with using the Hara d8 clutch with a MBX6r?? I have a ton of spare clutch bearings for the d8 and the sizes don't match up with the mugen
Zachfeen is offline
Old 03-13-2013 | 08:20 PM
  #18283
shajohan's Avatar
welcome...
they have for center too...
http://www.amainhobbies.com/product_...fferential-Set
shajohan is offline
Old 03-14-2013 | 03:29 AM
  #18284
welcome...
Thanks for the link man, and please let us know how you feel about the buggy after more testing in the track, cheers...
basher88 is offline
Old 03-17-2013 | 09:01 PM
  #18285
Steebo's Avatar
Will the mbx7 receiver box fit on the mbx6r? Anybody try it yet?
Steebo is offline
