Tekno SCT410 Thread >
Tekno SCT410 Thread
Like Tree17Likes
Tekno SCT410 Thread
Old 02-25-2013 | 11:29 PM
  #5806
DRRC's Avatar
Originally Posted by IIGQ4U
Are you on an iPhone or iPad?
Both and computer
PDF won't show the set up
It has the page but blank
DRRC is offline
Old 02-25-2013 | 11:36 PM
  #5807
IIGQ4U's Avatar
Originally Posted by DRRC
Both and computer
Try using Adobe reader on the computer. iPhones and iPads often have issues with setup PDFs.
IIGQ4U is offline
Old 02-25-2013 | 11:41 PM
  #5808
UK.hardcore's Avatar
Truck looks so nice IIGQ4U
UK.hardcore is offline
Old 02-26-2013 | 02:40 AM
  #5809
nanoverse's Avatar
Adobe Reader on iPad does the trick for me.
nanoverse is offline
Old 02-26-2013 | 03:45 AM
  #5810
Just got the traktion drive. Doesn't have instructions, and the instructions online just show how to put the shoes and springs on. I figured out how to put it together (I think) but where do the shims go, and how do I know how many to use?
rallyredevo is offline
Old 02-26-2013 | 03:53 AM
  #5811
They are for adjusting the play on the clutchbell.
you want it shimmed like everything, not too tight not too loose.
Old 02-26-2013 | 04:26 AM
  #5812
Play between what and what? What direction? Where would one put the shims?
Old 02-26-2013 | 07:19 AM
  #5813
Cain's Avatar
Originally Posted by teknorc
You need TKR5149, TKR5150. It's also a good idea to replace the diff case (TKR5113).
anyway to get this info added to the first page of the EB48 thread?
Went ahead and got some new pistons coming 1.3mm x 8 hole as well as the rest of the upper range of sway bars. Will report back on how they feel if they come in on time. for the Jam session monday, assuming I can go.
Here is a question for those who still use a center or rear chassis brace, but NOT both, which one did you prefer to leave on and why?
Cain is offline
Old 02-26-2013 | 07:53 AM
  #5814
sickpuppy1's Avatar
If you want to leave one of those braces on, leave on the center. The Idea of removal is to allow the back of the chassis to twist in order to make the back end stick better. So start with removing the rear and then if more flex is needed , go to center removal.
sickpuppy1 is offline
Old 02-26-2013 | 08:05 AM
  #5815
DRRC's Avatar
I would do the same after I try with all braces
I have an Mbx6 tekno conversion and there is alot of flexing bec of no brace at the back and I like the way it runs, if the SCT runs the same way without braces at the mid and back that would be great, and it would run better than my old scte
sorry didnt get any info on the shocks
but what is better standard or emulsion and what are the benefits for this truck
thanks
DRRC is offline
Old 02-26-2013 | 08:12 AM
  #5816
shipwama's Avatar
Since I dont see it listed on page 1 does that mean that the losi servo horn (aluminum) will give me issues? Thanks Can;t wait to get my truck
shipwama is offline
Old 02-26-2013 | 08:15 AM
  #5817
Cain's Avatar
I tried the removal process at the track, didn't notice that much of a difference for my conditions so I left them off. Afterwards, i wish I had tried removing the center only and leaving the rear to see how it felt. Especially as the rear is easy to disconnect but still leave on the chassis.
Oh well.
Anyone here running stiffer swaybars like 3.0, etc?
Cain is offline
Old 02-26-2013 | 08:22 AM
  #5818
FRONTI3R's Avatar
thanks
As stated by TeknoRC in the past:
The Team drivers suggest you use Standard bladder for smooth tracks and Vented Cap bladder for rough outdoor tracks. I built mine as Standard bladder since I will be running on Astro Turf. Also it's suggested that you always run with the shock boots.
FRONTI3R is offline
Old 02-26-2013 | 08:23 AM
  #5819
Between the clutch bell and the axle its on.
with traction drive it's easier too see how much it needs before you put it all together because the shoes put pressure on the bell.
Red circle on picture is where the shims go if needed.
Old 02-26-2013 | 09:51 AM
  #5820
rcbo's Avatar
The one I had on my losi would not work.The arm has to fit between servo and horn.
rcbo is offline
