Like Tree195Likes
Novarossi engines thread
Old 02-23-2013 | 05:21 AM
  #4546
Het is talking about the P/S set and not the P/S/R set. The 35+ with the right rod (P2 I believe) goes fine.
Roelof is offline
Old 02-23-2013 | 07:37 AM
  #4547
wmay11's Avatar
35+ piston and sleeve will work, 359 run P type rods.
wmay11 is offline
Old 02-23-2013 | 07:38 AM
  #4548
wmay11's Avatar
Thanks Roelof, dits wat ek bedoel het
wmay11 is offline
Old 02-23-2013 | 08:10 AM
  #4549
Ive actually broken the crank on it already(known problem), I ended up putting a JP crank on it and I use a R7 rod, Im just not sure which P/S set to use. My research indicates a Flash P/S, but if the 35+ set is cheaper...
Nitrodud? Thats new one lol, my favorite is nitroduche! lol
nitrodude is offline
Old 02-23-2013 | 08:06 PM
  #4550
SOLOARTIST 702's Avatar
Originally Posted by Pooh2
The rod is different. It won't work because of the pin on the crankshaft is smaller.
maybe the cordoba set then cuase it had diff. rod too i think
SOLOARTIST 702 is offline
Old 02-23-2013 | 08:52 PM
  #4551
wmay11's Avatar
What JP crank, Eagle does not work. Yes 35+ will work, if youwant to use R7 rod then you need to match the crank.
Bottom line 35+ will work. It is probably better spending money on a good used one or Kangaroo. It seems all you left with is crankcase, carb, bearings and button with head.
wmay11 is offline
Old 02-24-2013 | 07:55 AM
  #4552
The collari editions of the 35+21 P/S will work.
Collari, Collari Cordoba, Collari Lostallo.
fulcrum2 is offline
Old 02-24-2013 | 05:50 PM
  #4553
Thanks guys!
Old 02-24-2013 | 06:21 PM
  #4554
gotmotor's Avatar
Originally Posted by nitrodude
Thanks guys!
Dont waist your time with that P.O.S motor buy the stock picco for a practice motor My 359 lasted two fun%in races P.O.S
gotmotor is offline
Old 02-24-2013 | 07:05 PM
  #4555
I'm thinking I might just buy a 35+ for club races, and keep my other 2 motors for big races, save my money and buy keepon for the nats, or maybe even a Virtus.
Old 02-24-2013 | 07:53 PM
  #4556
so the jp R9s is better than the 359 i take it
Old 02-24-2013 | 07:54 PM
  #4557
gotmotor's Avatar
Um YES!!!!
gotmotor is offline
Old 02-25-2013 | 10:04 AM
  #4558
ToysRUsKid's Avatar
Quick question - which Nova plug should be used in a .12 Keep-On and a .21 Keep-On? I'm new to .21 this year so I don't know but I have always used medium plugs for the .12s. I check the Nova plugs and they all seem to be hot or cold so I'm not sure which one to use for each motor.
ToysRUsKid is offline
Old 02-25-2013 | 10:30 AM
  #4559
Can parts still be found for the TN12/Mugen M12 and NS12S3/Mugen X12?
performula is offline
Old 02-25-2013 | 05:31 PM
  #4560
i actually have a brand new mugen x12
