Tekno RC EB48 Thread >
Like Tree2Likes
Old 02-20-2013 | 07:17 PM
  #4876
Genebaby's Avatar
Originally Posted by LAZNICK RC
Thats good to hear check out t bone racing they make rear skid plates for eb48 also front skid plate / pro bumber looks like this one could provide better protection to chassies covers more of it then what comes with the kit see what you think!
Also can i ask why you bought two kits do you think that you will break 500 dollars worth of parts isnt cheaper to buy parts as you need them from amains their cheap for small orders and fast postage seems like alot of money waiting to be used in spare parts!
Maybe I'm a little crazy with this buggy but with part support locally non existent I checked out the prices and figured a whole car as backup will be nice. Down the line I may set up the other once I see how things go for me parts wise.
I actually got my TBR skid plates for front and back today too. I ordered them before I ordered the buggies, they were fairly slow to get them into the post. I have them on the Vorza so I got them again for the EB48.
Genebaby is offline
Old 02-20-2013 | 07:26 PM
  #4877
LAZNICK RC's Avatar
Fair enough i just think the eb48 is quite durable so i think the parts you will be replacing will be small cosumable items
What are the part numbers of front and rear skids from tbr!
LAZNICK RC is offline
Old 02-20-2013 | 07:42 PM
  #4878
Genebaby's Avatar
57002 & 57004 are the ones I got. The smallest ones. Not sure if the do the bigger ones for the EB48.
If I don't break much, and I hope not too, I'll run the other car with different ESC and motor probably.
I do have a serious lack of time problem to do the build, but I'll get there. Things were pretty busy and then I got into RC!
Genebaby is offline
Old 02-20-2013 | 08:05 PM
  #4879
slow_jun's Avatar
Originally Posted by jonasm48
The sct pro can run pretty much any motor with a 4s lipo. My motor is a long rotor 4 pole 2200kv truggy motor, and it's a handful. My sct pro handles the setup beautifully. I don't notice the 150a vs 120a sct pro esc running different really. I choose the sct pro because it is smaller and easier to access programming input. The sct pro is an esc that will blow your mind, I bet you'll ditch your rx8. Hw sensored esc's are so smooth, easy to adjust, and unbelievably cheap.
I have no ties to HW btw. I've had 4 Hw esc's and 2 Hw motors, all of them have been great. If I were you I'd drop the $90 on the sct pro and it'll be a bit less of a headache.
Just remember the sct pro isn't rated above 4s, so take that into account.
thats what i think so, i also have 2 HW esc but for 1/10th only, and been hearing good review on the 150 and sct pro ( modified 120A to accept 4S, am i right to say that, hahaha). only concern (now ) would be the weight biased if i changed to a much lighter ESC as my 2 Lipo ( saddle packs) setup is a bit heavy ( batt side) and if i changed to a smaller SCT pro, handling might be affected. thats my only concern but if the price is that cheaper then im only a basher so i could consider.
Thanks for your inputs...
slow_jun is offline
Old 02-20-2013 | 09:51 PM
  #4880
Desert Runner's Avatar
Originally Posted by Precision1
My motor can is 42.5mm and fits just fine. The only thing that limits the motor diameter is the center brace which most people don't run and is really easy to trim if it does contact (depending on spur size).
That's weird ! My motor is exactly 41.78mm in diameter ( hpi flux 2200kv ) and it needed to remove around 2-3mm from two of it's cooling fins in order to fit probably because the screw in the middle of chassis ( all showing in pictures on post #. 4489 at link below ) prevented the motor from setting correctly .
Check all pictures and modifications here :
http://www.rctech.net/forum/electric...l#post11738447
Desert Runner is offline
Old 02-20-2013 | 10:07 PM
  #4881
rcgod's Avatar
Originally Posted by slow_jun
Thanks a bunch.
Now this definately made me think twice, would a SCT pro be enough to power a 4 Pole monster? just want to know the pros and cons, other than that of the Burst and constant power. is the foot print. is the difference negligible when it comes to delivering power?.... or there is a significant difference?
SCT pro has same 120a continuous as mamba monster. Guys run the mmpro in 1/8 with no issues other than a weak bec and I believe it's rated at 60 or 80a continuous.
rcgod is offline
Old 02-20-2013 | 10:10 PM
  #4882
LAZNICK RC's Avatar
Question for you the front skid plate 57002 can you still use the front bumper supplied with kit to have that curved up protection up front ! Can the kit bumper be screwed together with 57002 aswell !
Or would you have been better of with 57001 which acts as a bumper and skid plate in one from tbr!
Old 02-20-2013 | 10:11 PM
  #4883
slow_jun's Avatar
Seems like you used the wrong screw, instead of the flat head screw you used the button head.
you used the wrong screw. (maybe TKR1401 Button Head Screw)
slow_jun is offline
Old 02-20-2013 | 10:21 PM
  #4884
slow_jun's Avatar
Or would you have been better of with 57001 which as a bumper and skid in one from tbr!
i think better to get the 57001 TBR as it has more meat to absorb the bumps, the 57002 has less protection.
i have always bought these Products for my sons kit and so far no major breakage.... good on the kits and good on my pocket. hahahha
slow_jun is offline
Old 02-20-2013 | 10:28 PM
  #4885
rcgod's Avatar
Double post
rcgod is offline
Old 02-20-2013 | 10:54 PM
  #4886
Matthew_Armeni's Avatar
I'm not sure where you got the 41.78 measurement from, but I'm fairly sure those fins go out to a 44mm dia. That dia., in addition to the tall gearing you have, is probably why you had contact there.
Matthew_Armeni is offline
Old 02-20-2013 | 11:14 PM
  #4887
LAZNICK RC's Avatar
Yes ok I thought so but can you still screw 57002 and kit front bumper together I like the fact that the 57002 protects the chassies further down its longer thus more protection I also noticed that the 57002 has some long screws up front shorter in middle and shorter again at the end of skid so iam thinking they may be able to be put together to form a great bumper / skid combination!
Old 02-20-2013 | 11:18 PM
  #4888
Genebaby's Avatar
The Tbone fronts are designed to be used in addition to the original bumpers. I gave the large on my Vorza but will probably change that one too.
Genebaby is offline
Old 02-20-2013 | 11:31 PM
  #4889
LAZNICK RC's Avatar
Ok so you are saying the 57002 can be screwed together with kit bumper hence the longer front screws in the front of the 57002
You may be able to screw the 57001 pro bumper with 57002 aswell ! hence the 57002 has longer screws in middle and shortest at the end of 57002
Old 02-20-2013 | 11:42 PM
  #4890
slow_jun's Avatar
Technically it is possible, but by doing so will only decrease the amount of ground clearance by sandwiching 57002 and 57001. it'll protect the chassis but in turn will make the front bottom more and may make the car run differently. But hay, im no expert just a basher...
slow_jun is offline
