Like Tree4Likes
Scale RC
Old 02-20-2013 | 04:35 PM
  #6226
jimuni.ss's Avatar
Originally Posted by Stpaul
Sorry sa previous post ko. Wala ata photo lumabas. Here it is. My DIY WIP Boyer Mog ni Jimuni.ss! Any suggestions are welcome!
Pogi! haha sabak na natin yan sa linggo hehe!
Originally Posted by Factory48
Meron akong stock ng 3Racing portal axles for SCX10. I don't know anything about the gmade axles. If you guys are interested just PM me. Naka-sale na mga ito.
Tempting.. XD parang tataas lang lalo CG pero totoong unimog nga naman naka-portal axle nga hehe. hmmm
Originally Posted by JCc4str0
Sir ilang mm ang pwede ilagay sa shocks ng tamiya cc01, naka 1.9 na tires yung akin, sumasayad kase sa body yung gulong, stock shocks po gamit ko ngayon.
Gaano ba kalaki tires mo bro? I use rc4wd tomahawks on my cc-01 it's around 3.9"-4" in diameter. Also using stock shocks, barely sumasayad naman sakin.
jimuni.ss is offline
Old 02-20-2013 | 04:57 PM
  #6227
mix237's Avatar
On a stock setup, you're a bit limited only to your stock shocks. If you do the front suspension lift mod, you can probably fit around 80mm shocks without having to drill out holes in the fender wells. The rear can take around the same size of shocks without doing any mods. What tires are you using now? Yung body ba is still the FJ40?
Originally Posted by pinoy_rc
mga sirs,
san po makakabili ng corrosionX for waterproofing purposes? nasa malls ba ito?
or any by-product common for waterproofing ng electronix.
Look for CebuRC's posts on the buy/sell thread, he sells corrosionx.
Originally Posted by djoverdose
Jimuni.ss,
Have 2 spare servo. Will take alook at it...
Also would like to ask what setup do you guys run on your wraith? Just finished building mine. Placed a brushless motor on it. with the stock axial rx and tx and stock gearing. Hirap macontrol ang crawl niya. Also using a HW 60a Esc with drag brake. Parang pag mabagal nanginginig yung takbo niya. Di siya smooth?
Is your brushless system sensored? If not, that's the reason why your rig is "cogging". Sensorless motors aren't smooth on low speeds.
BY THE WAY....ANY OF YOU GUYS HAVE A SPARE Y LINK? KAHIT USED?
mix237 is offline
Old 02-20-2013 | 05:47 PM
  #6228
wow, buhay na buhay ang scale thread! hoping to see more new builds and new faces! keep em coming!
leonv is offline
Old 02-20-2013 | 06:37 PM
  #6229
pinoy_rc's Avatar
yes sir, thank you.... at sa mga kapwa scalers... maraming salamat sa mga suporta at sana hindi kayo magsawa sa mga katulad namin newbies... it's an inspiration towards ongoing and growing hobby. thanks a lot bradirz...
pinoy_rc is offline
Old 02-20-2013 | 07:47 PM
  #6230
Leonv,
Yup. Guess the thread is getting lively every day. I hoe parts and accessories will follow.
Mix237,
Yes sir its sensorless. Ive thought about it too.... I really need some help on setting this rigs. I dont want to buy any unnecessary parts anymore. Need help on setting the proper gearing, motor and esc combo (brushed or brushless) want to do water crossings and the like if possible.
Heres whats with my scx10
-Axial Stock 27t brushed motor and esc.
-pinion 15T, spur 87t 48 pitch (just recently replaced the stock pinion)
*should i change to a 32pitch gear or should i just wait for gears to break down before replacing them?
-cvd shaft up front (still having some jerking at full turn.)
-placed 70grams of wheel weights on both tires
-changed the servo to tower pro high torque.
-aluminum upper, lower and steering links
-aluminum steering hub
Actually im abit ok with the scx10. Just need to sort out whats with the jumping axle at full turn. Had water proofed the esc too and all the electronic. Needs some trail time to further test the rig.
Wraith (kit)
- hobbywing 60a esc with drag brake for brushless motor
-novatech 3500kv brushless motor
-towerpro hitorque servo
-stock gearing
I wanted to tame the motor abit. But likewise since its a sensorless motor it cogs at low speed. Thinking of replacing the whole esc motor combo. Any suggestion? Brushed or brushless? Im on a limited budget. I guess it would be much better if i go brushed so that i can have low speed control and good for water crossing? Whats a good combo? Kung brushless naman po mostlikely sensored. Medyo expensive na sila pero would appreciate your inputs.
Should i put weights on the front wheel too? Ive cut the foam inserts into star already...
Sorry for such a long read.... I got to excited lately and purchased this and that.thinking the build would be a breeze... Im damn wrong. Took me two straight days to assy the wraith... Just manage to finish the rolling chasis and installed the electoronics. Im still not done with the lexan body.... Do i really need to buy alexan scisors?
Waaaa... Im overloaded..... Im doing three rigs all at the same time.....waaaaaaa need to calm my self....
djoverdose is offline
Old 02-20-2013 | 07:57 PM
  #6231
Factory48's Avatar
Default May masama akong binabalak.
Dahil wala na si Da Hulk...
Introducing DOKTOR OKTOPUS!!!!!!
This kit is a mixture of RC4WD, Axial, 3Racing, and other parts. Yung mga tira tira ko lang. Wala na kasi akong kit so hinalughog ko yung mga stocks ko and old parts box. Siguro naman with that axle hindi na ako sasabit sa mga bato. bwahahaha!
By the way, meron siyang dig and 4 wheel steering pero inactive. Masyado nang madaya. hehehe.
Still trying to figure out what to use for a ladder frame, shocks, and body mounts.
Factory48 is offline
Old 02-20-2013 | 07:58 PM
  #6232
Factory48's Avatar
Guys! I'm about to put in an order to RC4WD. Let me know if you guys need anything. Just PM me. Thanks.
Old 02-20-2013 | 08:03 PM
  #6233
Oh by the way ive read some where when using a high torque servo your rig needs to have a bec? Also whats the advantage of running a 3s lipo? Dipo ba mas bibilis siya?
F48,
Nice axles.... Will wait for your upcoming build.... Had placed the cvd already! Na lessen na yung jumping but its still there....
Old 02-20-2013 | 08:37 PM
  #6234
karnaugh2005's Avatar
DOKTOR FRANKIE..
karnaugh2005 is offline
Old 02-20-2013 | 09:45 PM
  #6235
inggit ako ah di pa makasama magscale
silent_racer17 is offline
Old 02-20-2013 | 11:34 PM
  #6236
elno's Avatar
Sir silent_racer17 sumama ka na kasi ulit sa Sunday afternn Feb24 sa P&W tayo!
Whoa! Sir Factory48 excited na ako makita result niyan bago mong project.
elno is offline
Old 02-21-2013 | 02:16 AM
  #6237
Dusty Road's Avatar
Sir Mix group buy na lang kaya, I'm sure gusto rin yan ng iba lalo yung mga sock pa
Dusty Road is offline
Old 02-21-2013 | 03:44 AM
  #6238
Gud day mga sir. Just got my cc01... Wanna ask lang po if fit po ba ang 1.9 tires sa stock na rims nito?? And if ever hindi meron po ba kaung mga spare 1.9 rims and tires?? Kht used lang po. Thanks.
gennomaria is offline
  #6239
Default pasingit sale
aramacir is offline
Old 02-21-2013 | 06:21 PM
  #6240
Leonv,
Mix237,
Wraith (kit)
-stock gearing
Pambihira! ang dame na agad upgrade? heheh sarap naman!
acpaungan is offline
