Scale RC
#6001
I have no experience shipping it directly here, usually nakikipadala lang din. Other members might have experience on shipping it here.
But like sir mix's advice, just keep on checking our threads or the buy and sell thread and most likely you'll find what you're looking for.
If you want to save cash, just build it. This is what scalers enjoy most.
#6003
gud day mga sir, papatulong sana ako kasi bago alng ako sa hobby na to, pangolin po ung crawler ko na 1:10 scale, papaturo lang po sna ako kung paano po mag water proof ng servo, nag try na ako sa youtube pero di ko po kasi sigurado kung yung mga grease na nilalagay nila dun eh meron sa mga hardware natin dito at may iba kasi nilalagyan pa ng o-ring yung sa horn. eh san po ba ako makakakuha nun? pls help
thanks in advance guys
#6004
#6005
By the way mga scaleheads, since Stpaul is asking if we can do class1 again, pls indicate below what class you'll be joining to see if there's a quorum. And, although it may be far for the "north" scaleheads, lets try again in Dusty's Track, its easier to organize the comp there, we've got easier access to basic facilities (CR, tables, chairs, food etc.) and the others haven't been able to try it out yet. Madali naman puntahan, lalo na Sunday. Sa next comp we'll do north area again. Hope this is alright with you guys.
ROLL CALL NA!
1. mix237 Open Class/Class1
2. SLK200
3. Dusty Road
4. F-Series
5. Stpaul - Open class/Class 1
6. Jimuni
7. Factory48
8. scaleca46
9. leonv
10. Elno (class1) if ever sa open class din
BY THE WAY AGAIN.....SHARE KO LANG.....NEW LOOK OF CC-01 "BASTOS"
(MOCK UP PA LANG...HEHE)
ROLL CALL NA!
2. SLK200
3. Dusty Road
4. F-Series
6. Jimuni
7. Factory48
8. scaleca46
9. leonv
So it's dusty's track tayo this 17th? Sabay ako sa carpool. Share nalang sa gas and toll fee!
#6006
Hope this helps. Happy trailing and crawling and welocome to our very addicting hobby! Attend our almost weekly gathering para enjoy! As mix said "malungkot magtrail magisa!"
#6010
I used ordinary automotive grease available on any auto supply. Filled the gears part of the servo. Then I used RTV, also available on any auto supply. Applied it on the electronics side on the servo naman! Apply it on all the cracks and openings on the servo body casing.
#6013
just had the front solid axle of my tf2 re-shimmed and replaced the rusted and stuck ball bearings with greased bushings. was actually surprised how deep mud could ruin your bearings. lesson learned, grease and clean the mud right away. dont let it settle and dry. tsk tsk..
was also considering the idea of keeping the bushings there instead of bearings. they both need to be greased and cleaned anyway, any ideas if this would work? with the way I use my rig, I think my bearings would get rust anyway so why not use bushings, they're cheaper to replace than bearings.
#6014
sir jess do you have this kind of product?
http://store.rc4wd.com/Cyclone-24mm-...ors_p_163.html
wheel adaptor ba yun, parang mas ok kasi yan kesa naka direct yung mismong wheel hub ng rc4wd wheel sa axle shaft.
sir mix yan ba yung inquire mo dati, naalala ko lang nagpost ka ng ganyan?
#6015
Yup! Built from scratch ang ladder frame ng dingolin. From T6 aluminum sheet. Walang nabibili locally ng frame but you can either order online or from jess of crazy crawler. Aka f48. I think!
4Likes
