The AE FActory Team B44.2 Thread
#2072
hi.
so im making a shopping cart and this is what came out:
B44.2
mamba max pro ESC
tekin redline gen2 6.5t
savox 1258
rpm ball cups
out drive boot set #1 TDR310022
out drive boot set #2 TDR310023
losi bleeder screw
pro line bulldog
diff ring
front arms
the site wont let me insert links for the products... (?)
what do you say about the set up? is it good?
the mamba max pro with the gen2 combination is good?
any thing else i need?
B44.2
mamba max pro ESC
savox 1258
rpm ball cups
losi bleeder screw
pro line bulldog
diff ring
front arms
#2075
Go with a RS Pro or R10 or other smooth small esc. The mmp will take up a ton of space on your chassis... may not even fit. Not a good match for this kit.
Just say no to savox, fitment and amp draw issues. AE or other servo.
If new to 1/10 4x, start with the gen2 7.5t. 6.5 is a handful when getting accustomed to the car. I haven't driven a 1/10 4x in about 8 years so might as well be new to it and in hind sight I would have been better off with a 7.5t.
Losi diff screw bag with washer is good to have for $2 IMO.
Ball cups and take your pick of spares is all that's needed.
hi.
B44.2
mamba max pro ESC
savox 1258
rpm ball cups
losi bleeder screw
pro line bulldog
diff ring
front arms
B44.2
mamba max pro ESC
savox 1258
rpm ball cups
losi bleeder screw
pro line bulldog
diff ring
front arms
#2077
+ 1000 8.5 is plenty start at low end of gearing and radio and as you tune boost up,I used stock diff rings without sanding and diff has lasted well over 2 months of twice a week racing!
This will help you enjoy the car even more as you learn with the car?
#2078
#2079
Sure would look funny hobbling around the track on nicely prepped hubs and AKA inserts!
#2080
i wanted to take the mmp cos the tekin combo costs allot!
i have two savox and i like them. but i can try other servos.
i new to 1/10. now i drive the rc8be and a crawler.
i dont want to buy a 7.5 motor and after a month replacing it. ill ask my track guys what they are driving.
what is the losi diff screw?
aside from the front arms and diff ring, any other part is needed?
#2081
thanks!
#2082
I've run a Savox 1258, and Spektrum 6040 on 3 different Tekin ESCs with no issues. I thought the glitching issues had more to do with running Spektrum radios?
I'm using an M11x.
I think the Savox sucks, but my Orion died at an away race, and that's all that was left. I absolutely LOVE my Futaba BLS451 in my wheeler though. If I could do it again, I'd go with the BLS 551 (low-profile), so that I could get all of my electronics on the left side.
I'm using an M11x.
#2083
I'm using an M11x.
I'm using an M11x.
#2084
I'm using an M11x.
I'm using an M11x.
#2085
thanks!
sorry, was rebuilding my diff when I wrote that. Bleeder screw & washers.If you got savox, use it... just was saying don't go buy one. Sand some material off the face of the servo mount if needed to clear the steering link, no spacers.
You may be faster with lower than 6.5 for a whole season, not a month. Or maybe not.
I always over power so I may not be the right person to comment... case in point, I have the 6.5
