Like Tree2991Likes
1/12 forum
Old 01-05-2013 | 12:21 PM
  #38956
Pulse_'s Avatar
Originally Posted by InspGadgt
LRP SXX V2
Orca VXI
But it looks like the SXX may be out of production...AE doesn't list it on their site any longer.
thanks! never heard about the Orca VXI I'll take a look
Pulse_ is offline
Old 01-05-2013 | 07:23 PM
  #38957
butrflynlambie's Avatar
went through and determined what I needed to finish out this old project ftm ftr 12 project.... some missing parts. Looks like I'll just park the project for awhile and considering the tbar cars are now somewhat obsolete. Thinking of a TC Kit.
thanks everyone for the excellent advice.
used the team associated manual for parts
1403 - 1.65" turnbuckle (2 needed)
6274 - ball cup (4 needed)
4626 - steering block (2 needed)
4627 - front axle (2 needed)
4673 - bhcs M2.5X0.45X4 (2 needed)
31550 - locking nut (2 needed)
6284 - 4-40x.250 (6 needed)
4554 - rear axle shims .250 (4 needed)
4630 - Servo mount (2 pcs)
4624 - spacer (2 needed)
7337 - washer (4 needed)
31532 - M3x8mm bhcs (4 needed)
31280 - ball stud 5mm short (2 needed)
31550 - M3x0.5 locking nut (2 needed)
butrflynlambie is offline
Old 01-05-2013 | 10:50 PM
  #38958
There is also the Team Orion R10 1-2s, no receiver pack needed.
avink007 is offline
Old 01-06-2013 | 02:27 AM
  #38959
Pulse_'s Avatar
thanks, so here is the list of esc that need no booster for 1s application:
viper vtx1
hobbywing 1s 120A
team orion r10
orca VX1
If somebody knows about another one, let us know
Pulse_ is offline
Old 01-06-2013 | 02:33 AM
  #38960
corallyman's Avatar
viper vtx1
hobbywing 1s 120A
team orion r10
orca VX1
Not sure you know this but there are several versions of the Orion esc, the one you'd want is the r10 pro 1s-2s version.
corallyman is offline
Old 01-06-2013 | 05:27 AM
  #38961
Conrad's Avatar
viper vtx1
hobbywing 1s 120A
team orion r10
orca VX1
CoreRC Pace 45R, limited to blinky racing but no booster required.
Conrad is offline
Old 01-06-2013 | 05:46 AM
  #38962
Viper vtx1
hobbywing 1s 120A
team orion r10pro 1S
orca VX1 Titanium
CoreRC Pace 45R
LRP SXX v2
Nosram Pearl v2
Yokomo BL-PRO2T
Yokomo BL-RS2
Turnigy TrackStar 1S
I just add to your list.
ongbenghui is offline
Old 01-06-2013 | 11:40 AM
  #38963
Pulse_'s Avatar
many ESC I've never heard of, it's getting interesting
Most of you might not care but I WILL HAVE MY FIRST EVER PAN CAR YEEHAAAAAA
CRC XTi
New in box, half the price
Pulse_ is offline
Old 01-06-2013 | 12:12 PM
  #38964
With the Xti there isn't much room on the chassis for electronics. I would highly recommend the Viper for that since it is the smallest. The footprint is the same size as the Tekin RS only you don't need a booster. The down side is because the case is all aluminum it is quite heavy compared to the other ESCs.
InspGadgt is offline
Old 01-06-2013 | 12:34 PM
  #38965
andrewdoherty's Avatar
Receiver can make a difference too. I have a two Xti's both with the HW 120A 1s and they fit fine, and neatly IMHO, with a KO 407s. I wouldn't have a chance with a bigger receiver though. The HW is about 3-4 g heavier than the Tekin despite the larger footprint. Its just about a wash when you consider a booster or rec pack.
andrewdoherty is offline
Old 01-06-2013 | 01:30 PM
  #38966
Pulse_'s Avatar
Ideally I would like to use:
- sanwa 451 receiver
36.5 x 24.0 x 15.0mm
just to do the comparison the ko407s is 28 x 18.3 x 18.5 mm...
- s9650 servo
Length:1.42 in (36.1 mm)
Width:0.59 in (15.0 mm)
Height:1.14 in (29.0 mm)
- HW 1S ESC
43mm(L) * 36mm(W) * 33mm(H, with cooling fan)
The HW isn't small..
Maybe I should have bought a 12R5.2
Pulse_ is offline
Old 01-06-2013 | 01:38 PM
  #38967
No9's Avatar
No9
- s9650 servo
- HW 1S ESC
The 12r5.2 may have been a better way to go ,my mate used his new xti only twice before it literally fell to bits.
Had to order the new upgrade chassis kit,so it is now a not so cheap car.
No9 is offline
Old 01-06-2013 | 02:11 PM
  #38968
Radio Active's Avatar
Remember, it is possible to mount a receiver on its side and save space that way. Some of the 2.4 GHz receivers are so small that you could even consider mounting them on top of the servo in an Xti given that the servo you have to use is also tiny!
Radio Active is offline
Old 01-06-2013 | 02:51 PM
  #38969
Pulse_'s Avatar
What is smallest size of cables I can safely use in a 1/12:
- between the ESC and motor?
- between the motor and lipos?
I'll need to save some room
Pulse_ is offline
Old 01-06-2013 | 03:05 PM
  #38970
Unless you are going mod racing...use 16awg.
