SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 12-28-2012 | 11:01 AM
  #2191
Originally Posted by JJay03
I was planing on big bores eventually and getting some good tires asap. What you mean by glueing the rack?
he meant the steering rack, where the two parts meet right below the servo saver spring. what it does is that it makes the steering more accurate and responsive. or you can upgrade to the avid, jconcepts or even the ae rack which deletes the need for the servo saver
derbrylac is offline
Old 12-28-2012 | 11:02 AM
  #2192
Originally Posted by Bob Barry
Steering rack. That's more important than everything except the right tires of course. If you don't either glue it or replace it, it deflects when going into a turn and makes your truck feel like it has a 8 foot snow plow on the front of it.
Is there a thread on this? Im sure ill see what you mean those once the truck comes in the mail.
JJay03 is offline
Old 12-28-2012 | 11:13 AM
  #2193
Wildcat1971's Avatar
Tech Prophet
well more precisely the servo saver gets glued up.
Wildcat1971 is offline
Old 12-28-2012 | 11:21 AM
  #2194
Any aftermarket aluminum ones I could get for a spektrum s6040?
JJay03 is offline
Old 12-28-2012 | 11:37 AM
  #2195
Would these resolve the issue?
http://www.amainhobbies.com/product_...crank-Set-Blue
JJay03 is offline
Old 12-28-2012 | 12:07 PM
  #2196
I just got a new FT kit what if any upgrades would you guys do to this truck?
I'll give you my list: MIP cvd kit
Robinson Racing pinion
Brushless Hobbies LT4 120A esc
Avid RC wheel hex set
BFast Pro Diff w/ ceramic balls
RPM front & rear bumpers, skid plate, chassis brace
Lunsford Racing titanium SD turnbuckles & hinge pins
Integy alloy bellcrank
AE B44 rear hubs
AE #9880 steering block, #9881 front axles
#7495 V2 vented slipper hubs
Integy #T7838 alloy caster blocks
Fantom Racing ION v4 Pro 7.5T w/abec7 ceramics
Hitec HS5645MG steering servo
AE big bore shocks & Avid RC spring kit on the way
Johnnysplits is offline
Old 12-28-2012 | 12:11 PM
  #2197
Nice
I definitely need to get the rpm bumpers asap.
AE B44 rear hubs
JJay03 is offline
Old 12-28-2012 | 12:57 PM
  #2198
I ordered the rpm front and rear bumpers and ball cups. I might get the bell crank setup local.
JJay03 is offline
Old 12-28-2012 | 09:47 PM
  #2199
njnewc's Avatar
JJ, Get some track time with the FT Truck. All of the "upgrades" won't mean anything if you can't get around the track. The Niceities like Big Bores and Alum steering racks will help but things like new CVD's, Turnbuckles, Diff, RPM bumpers, etc are not neccessary IMO. The FT team equip is very high quality... Hexes make it nice because you can use the same tires on the front and rear, other than that they really don't serve a performance upgrade. I would reccomend when you do decide to get some new tires to go with the +3mm rims. I use DE Borrego rims, I like the way they look. Hope this helps
njnewc is offline
Old 12-29-2012 | 06:07 AM
  #2200
forwardonly's Avatar
I agree! I run mine bone stock and do very well. I still run the stock wheels as well and haven't had a problem. Drive it stock until you can push it to it's limits then you can begin to tune it and figure out what performance upgrades you want.
forwardonly is offline
Old 12-29-2012 | 07:18 AM
  #2201
Thanks for the tips. I got the rpm bumpers cause im sure ill be crashing a lot at first.
JJay03 is offline
Old 12-29-2012 | 09:03 AM
  #2202
???E-Racer's Avatar
I have made a good decision. Im gonna run my Losi esc and Team Checkpoint 19T "Money Motor" in my mod factory team sc10 until it gives up on me.
I have it geared 84/19 im pretty sure it will be fine geared this way.
I was gonna run a 10.5 brushless system in it anyways, so that can help
getting me prepared for that upgrade. That team checkpoint motor is a BEAST on Lipo power. I really wish that company was still around. They made the best brushed motors money could buy!
???E-Racer is offline
Old 12-29-2012 | 09:10 AM
  #2203
Tech Prophet
I was running a brushed more in my kids sc10 with a lipo. It got tor up pretty quick. I still have my lathe, so I can cut it. But that motor wont last too long. A 10.5 will haul butt though. I tried one in my sc10 and even boosted it a little and it haul booty around the track.
Old 12-29-2012 | 09:13 AM
  #2204
Cptn Cartwheel's Avatar
They're called TrakPower now. Check em out.
Cptn Cartwheel is offline
Old 12-29-2012 | 09:15 AM
  #2205
Tech Prophet
wait team check point changed their name? I though track power was a Tower Hobbies brand
