Viper RC -
#6287
#6288
#6291
CHANGE PROFILE WITHOUT A ProGauge
1. Connect a proper/charged battery pack to the ESC.
2. Power on transmitter.
3. Press and hold the red power button on the V-PORT for three seconds.
(Followed by beep tone, F/N LEDs on the V-PORT will be indicated as the image shown at right)
4. Press the corresponding number of time of the desired profile (refer to TABLE.1 below) on the red power button
on the V-PORT. For example, press 5 times if you wish to load profile 5. The F/R LEDs will be indicated on
every button press.
5. Release the power button for 3 seconds. The VTX ESC will save the profile number and F/R LEDs will be
flashing the number of time of the corresponding profile that it was saved.
6. The VTX ESC will then run an auto system reset. The F/R LEDs will be flashing the corresponding profile number
every time after beeping of system initialization.
Practice mode is PROFILE 8 This is the only profile that includes reverse
Hope that helps.
#6292
MaplestreetRC, welp, only problem is I'm unable to locate my manual. I've got it somewhere, just like I have the progauge somewhere, but, when my wife moves my stuff, "somewhere" is an abyss.
But, thanks so much for your reply. W/out the chart/table etc. I'm still not able to get there.... *sigh*
#6293
Practice mode is profile 8.
So just do steps 1-3 then push the button 8 times, that puts you on profile 8, then do step 5 and 6 and your'e there.
#6294
#6295
#6299
If that's not a concern then the VTX10-R (RED Or BLACK edition) is a suitable and less expensive option for 4x4 Short course trucks. You can run any turn 540 motor and up to a 4.5T 550 motor.
4Likes
