Power problems with hobbywing kit. >
Old 12-14-2012 | 01:46 PM
Default Power problems with hobbywing kit.
I have a Hobbywing 120A esc paired with a 5.5t Brushless Hobbywing motor but i have a recurring problem.
With grip tyres i have full power for about 15sec, then the motor only works at half capacity for maybe 10sec... then the esc cuts out for 3sec... and when it comes back on i have full power again and the cycle repeats. I had the same issue with my last Hobbywing set up. (60A esc / 9T brushless)
I have replaced receiver, as i had heard that can sometimes be the fault... with no luck....
Really starting to annoy me now...
Any help would be much appreciated!
Wes
sirweasle is offline
Old 12-14-2012 | 02:21 PM
gogi108's Avatar
Wes
probably lipo cut off LVC , check cut off , set to 3.0 per cell , if its not this your batteries are not capable of powering a 5.5 brushless .
gogi108 is offline
Old 12-14-2012 | 02:24 PM
remove red wire on RX plug from esc.. Install a Ubec.. ur problem will be solved on both esc..U are over taxing esc bec..thats ur issue ONLY..I guarantee this statement..
tntpoof is offline
Old 12-14-2012 | 03:00 PM
I believe there are different size ubec, what do you recommend.
Also, im not using a lipo. im using a 5100 7.2v nimh
Old 12-14-2012 | 03:43 PM
dtr's Avatar
dtr
I bet that nimh cannot sustain the voltage under the load of that motor.
dtr is offline
Old 12-14-2012 | 04:15 PM
JimmyG's Avatar
NiMh will not be able to handle the motor setup. NiMh do not like it when you get over 50 amps of draw. The voltage drops off.. Get yourself a lipo.
JimmyG is offline
Old 12-14-2012 | 04:52 PM
Yeah, I had been thinking it may have been the case. Any sugestions for a lipo? No real budget but I dont want to mortgage my car to get it
Old 12-14-2012 | 04:57 PM
xrocket21's Avatar
Gens Ace 5000 lipos ftw
hobbypartz.com/98p-40c-5000-2s1p-hardcase.html
buy these, love these, enjoy these, be happy with these
pretty much the SBC of lipos
xrocket21 is offline
Old 12-14-2012 | 06:04 PM
I stand corrected the NIMH are ur problem Upgrade...
tntpoof is offline
Old 12-15-2012 | 02:35 PM
Thanxs guys. Tried a mates lipo yesterday works a treat and it has alot more power... whether thats a good thing or not tho.
