RC10B4.1 FT/WC
One of the first things you should check before tearing apart your tranny is your spur and pinion gear to make sure those two are still good, especially the spur. Also check to make sure your gear mesh isn't to tight.....Also check to make sure you didn't tighten down the screws to tighten that holds the motor plate to the tranny because you can get some rubbing if it is.....
Since you didn't ask about the AVID, i'll rate the 3 spurs you listed:
1: Kimbrough(light and high quality)
2: JC Silent Speed(Machined teeth, i like the precision. Downside being available sizes and possibly heavier)
3: AE stock spurs(rumors say Kimbrough makes em for AE, but their own are higher quality than the ones they sell AE)
I like Robinson pinions, recently started buying their black anodized aluminum pinions and love em. Less weight and to me, they seem quieter and make a better noise than the steel ones, more of a "Whirring" sound.
Offroad newbie here (well scale offroad anyway)
I have just picked up a B4.1 FT, having never driven offroad before, but plenty of onroad, I would like to know what spares do i need to buy ?
What the weaker points on the car ?
Do i really need to upgrade anything while i am learning, or will the kit be fine for a few months ?
I have seen there is a wheel hex upgrade is this worthwhile ?
I will be running in 17.5 so it wont be too abused.
Beth.
Beth.
Gear diff, correct? Sounds like your diff is skipping. You can either get some shims and shim it or upgrade to a ball diff. I've never actually run the gear diff...just heard it acting up plenty at the track.
Just wondering that maybe someone on here may be able to solve my problem. I have the stock rtr b4.1 and recently after my second running, I notice my gears making a louder noise than usual. I just tore my tranny down and my spur/gear mesh is fine. Going into the tranny, all the gears look to be fine. For a sec I thought the main diff gear was stripped, but I believe the main diff gear itself just have very small teeth to accommodate the small tranny space.
When I had my car sitting on the table and holding it down and throttle, I had a loud gear noise and it seems like I wasn't getting a lot of power.
Can anyone identify my problem?
Beth.
Beth.
1. Avid aluminum steering rack (a must to eliminate slop)
2. Hexes
3. Triad Slipper by Avid (hold out on this, jury is still out, the stock V2 is pretty stout)
4 Big Bore Shocks (associated finally came out with their own and they are great, they arent Kyosho great but they are pretty damn solid) and for the price of a pair kyosho springs you can get a full set for one end of the car with cash to spare.
For now hang out here, very knowledgable group with lots of input on your new ride.
Kevin
Beth.
Beth.
The parts I most often break are rear ball studs (black and silver), rear ubrace and front arms.
Beth.
Beth.
typically, the front towers and arms break the most while learning to jump, sometimes rear towers and caster blocks.
if you have the FT WC you won't need any upgrades to learn, if it's a FT then the +8mm chassis is nice.
hexes are convenient, but not necessary, and might be the way all wheels go in the future; cross compatibility with other brands is a plus
Beth.
Beth.
