RC10B4.1 FT/WC
Old 11-27-2012 | 05:55 PM
  #24706
RC_nooberton's Avatar
Originally Posted by YankeeFan123
I have and really like the Hitec X4 charger, reasonable price and it gets the job done.
Hey YankeeFan I have this charger on the way from A-Main. http://www.amainhobbies.com/product_...-6S-6A-50W-x-4 I can't really tell from the description but I'm running Gen'sAce bullet style batteries which don't have a balance plug. Do I need to purchase anything more or can I charge these with the charger as is?
Thanks man.
RC_nooberton is offline
Old 11-27-2012 | 06:05 PM
  #24707
Wildcat1971's Avatar
Tech Prophet
It changes the roll center. Making it feel lower to the ground.
Wildcat1971 is offline
Old 11-27-2012 | 06:15 PM
  #24708
YankeeFan123's Avatar
Thanks man.
Yes that's the charger I have/use, what do you mean it doesn't have a balance plug?
I also have some gens ace and I don't know what you mean.
YankeeFan123 is offline
Old 11-27-2012 | 06:19 PM
  #24709
Tradin Paint's Avatar
The Gens ace does not have a balance plug coming out of the battery. It uses a balance port with the small bullet connector. In looking at the plugs it comes with I don't think it has the right one to charge with 3 bullets on the battery end. What are you using on your Gens Ace packs
Tradin Paint is offline
Old 11-27-2012 | 06:27 PM
  #24710
Venom1836's Avatar
Originally Posted by Venom1836
Double Dees and Green V1 Barcodes are both good at my local track...
imo, that is weird. They are a completely different tire. But I am sure it is possible.
http://www.teamassociated.com/pdf/ca...ceway_2012.pdf
http://www.youtube.com/watch?v=3_UrCRICetU&feature=plcp
Theres the track I run on.
I am currently running 3D's in green and they feel good. (Aren't 3D's like a mix of Double Dees, Goosebumps, and Barcodes?????)
Venom1836 is offline
Old 11-27-2012 | 06:33 PM
  #24711
Can you use the the B- hubs with the shaved brace on a medium to high bite track, and how will that work together
MadKam is offline
Old 11-27-2012 | 06:41 PM
  #24712
Autocratic's Avatar
Originally Posted by ryanpatrickgore
the difference is that the C mod changes the roll center because its lower position. = higher roll center
C hub lowers the roll center.
Autocratic is offline
Old 11-27-2012 | 06:45 PM
  #24713
TRyan's Avatar
yeah, the JC design is way better than the AE design. But i have not seen the price tag yet.
Not a big fan of the AE design this should be a big improvement. I've seen them from 9-11 dollars a set but they say they won't have them until late Dec.
TRyan is offline
Old 11-27-2012 | 06:49 PM
  #24714
Tech Prophet
3d's are not the same as double dee's. They are a bar style tire with pins. I have never seen them in use, but from what I have read they are for dry dusty hard tracks, which yours appears to be. but in that video I see a bit of blue groove. Still that is way higher bite than the Double Dee tire tracks here. We can rooster down the straights
Old 11-27-2012 | 06:58 PM
  #24715
l
These are the Gen'sAce batteries I use. http://www.hobbypartz.com/98p-50c-50...case-2222.html I have to use the banana plug adapter now. I'd like to lose the banana plugs.
I guess I could snip them off and solder on some bullet plugs.
Old 11-27-2012 | 07:00 PM
  #24716
Tech Prophet
take a picture RC, i think we are lost
Old 11-27-2012 | 07:26 PM
  #24717
ryanpatrickgore's Avatar
yes, you can add 2 washers to get back to the unshaved height also. I am running the shaved brace with 1 washer and the B hubs. so thats kinda like -1 washer. and right now i really like it on my track (medium bite) it locked my car in a bit and it feels better to me. I have tried standard b and the c hub mod as well. i am about 1/2 a second faster average since the change.
maybe not for everyone tho, im no expert, but im not bad
ryanpatrickgore is offline
Old 11-27-2012 | 07:33 PM
  #24718
I may give it a shot for a change. I am a B-Mainer at best so probably won't notice a difference.
MadKam is offline
Old 11-27-2012 | 07:37 PM
  #24719
im a upper b-mainer to A-bumper, haha i did feel a difference, you will if you test back and forth a few times to get the feel
  #24720
Sorry I edited the original post. But here is my battery http://www.hobbypartz.com/98p-50c-50...case-2222.html
