RC10B4.1 FT/WC
Old 11-14-2012 | 09:39 AM
  #24001
Matt Trimmings's Avatar
Wish you correct, sorry ..
Had the same discussion with someone
that's doing as you last night ...
All I'm saying is that I built it, it works fine. Sorry you didn't do it correctly. Lets get onto something else.
Matt Trimmings is offline
Old 11-14-2012 | 09:42 AM
  #24002
Wildcat1971's Avatar
Tech Prophet
So back to this center line mounting of the esc.
- I can see how the car may react faster
- I can see how it might be easier to correct in the air.
- I do not see how it would land better.
I think about it like this. if I put a weight at the end of a 6 foot stick, it takes more energy to move it from point A to point B. If I move the weight much closer to me, it would require less energy to move it. I am referring to circular movement not linear. I always looked at the triangles like that. Weight out from center would calm the car down in bumps that tilt the chassis from left to right. And would also slow down the car when changing directions. But land jumps is a downward force, so how center line mounting would help, makes no sense to me.
Wildcat1971 is offline
Old 11-14-2012 | 09:44 AM
  #24003
Tech Prophet
I saw Matts car last weekend. It looked like a solid build and ran well. Well he crushed me at least, lol. If he says no binding, I am sure he has no binding.
Old 11-14-2012 | 09:47 AM
  #24004
Wild Cherry's Avatar
hey , my ride is smooth & tight , your's ????
Wild Cherry is offline
Old 11-14-2012 | 09:57 AM
  #24005
same...as always
Old 11-14-2012 | 10:04 AM
  #24006
Ok Matt ...
Only attempting to help & not intending to call you out ...
Old 11-14-2012 | 10:19 AM
  #24007
Originally Posted by sunco1
How are you guys routing the servo wire through the chassis? Drill a small hole and take off the plug on the wires and send em through? That's the only way I could think of without drilling a super large hole
Correct. Small holes take the plastic plug off with a exacto run the wires threw then slide the plug back on.
micrors4guy is offline
  #24008
NUZUM's Avatar
Any time weight is placed on the axis point and close to the centerline of the vehicle it will rotate quicker ... Polar Moment of Inertia...
NUZUM is offline
Old 11-14-2012 | 10:49 AM
  #24009
Tech Prophet
yep, I got that. But I dont get the landing jumps better.
Old 11-14-2012 | 11:17 AM
  #24010
Waflet's Avatar
Hideeho
I would assume when landing a jump off center the buggy will roll back to center quicker on landing.
I tried my ESC in front of the battery a while back & really didnt like it. I think that had more to do with not having a sensor wire long enough & not spending the time to work on settings. Some time in the next month or 2 (last 2 points series races coming up close together so no time for setup changes before them) I plan on trying the ESC behind the battery with a sensor wire. Honestly I don't think I will like it as that moves the battery farther forward than I want. I will also pick up a longer sensor wire on my next order & try it in front of the battery again.
Waflet is offline
Old 11-14-2012 | 11:26 AM
  #24011
Aoh
Hope your also using the Losi ball stud , if your using the Ae stud & the Losi ball cup ?
way tight & bind bad ....
BTW
If you did use the Ae stud and they are not binding ?
The losi cups are already worn out & and most likely the ball studs as well... ...
Switch to RPM & Ae stud , more betta
PS get your hex's hubs on there , whats the hold up ?
i kinda break them in by hand, so far so good, i dont pop links much unless its worn out, which only happens on the rear.
i definitely popped more links when i was running the rpm
not using hex fronts because i have too many front bearing wheels/tires. i also share the front wheels with my gold pan rc10
Aoh is offline
Old 11-14-2012 | 11:53 AM
  #24012
Originally Posted by Aoh
.... i also share the front wheels with my [Super Dailed] gold pan rc10
BTW, Thanks for letting me drive that classic!! Still can't believe how
good that thing drives!..WOW.
EZSC is offline
Old 11-14-2012 | 12:22 PM
  #24013
Sean Dickinson's Avatar
The reason the car lands better is due to the weight being in the centerline. Having weight on the extremeties of the chassis tends to transfer weight more so than the centered setup. The weight stays in the middle and returns there quicker when jumping angled or slightly whipped. It just allows the car to settle quicker, to keep it simple.
Sean Dickinson is offline
Old 11-14-2012 | 12:34 PM
  #24014
So is my girlfriend.
Sorry I asked about the ball cups. So the final word is Losi cups with AE studs? When you say Ti-nitrade are you talking the TC 6 metric ones or the SAE ones?
zipperfoot is offline
Old 11-14-2012 | 12:38 PM
  #24015
idrummerboy13's Avatar
ballcups-the new tire discussion
idrummerboy13 is offline
