SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 11-10-2012 | 03:59 AM
  #1666
Wildcat1971's Avatar
Tech Prophet
ok, 13.5 blinky gearing starting point? 24/81?
Wildcat1971 is offline
  #1667
rimracker's Avatar
Originally Posted by J_Bone
You have a point, but I will have to disagree. With out enough weight your tires will not get sufficient traction whether it be forward, aft or side to side.
I believe this is also a regional/track issue. I run blinky 17.5 with a shorty on our local track which is probabably smaller than most of you are running on. The shorty without a doubt transitions faster on all the tight turns. The downfall is when the track gets blown out like last week than you have some issues. No weight in the truck, electronics down the center, Speed Passion, Airtronics, hang on.
rimracker is offline
Old 11-10-2012 | 06:53 AM
  #1668
MD's Avatar
MD
When you look at most of the setup sheets from Associated, the drivers use some kind of weight in the rear.
MD is offline
Old 11-10-2012 | 09:44 AM
  #1669
Tech Prophet
I am trying no weight and battery forwards. And I have a lot less steering with no lead in the rear
Old 11-10-2012 | 10:51 AM
  #1670
J_Bone's Avatar
I'm geared 24/78, so you could be close or perfect for your track and motor.
J_Bone is offline
Old 11-10-2012 | 06:16 PM
  #1671
Tech Prophet
I ran sc10 for the firat time tonight. I bought some AE hexes. They seemed solid but I think the avid look nicer and have longer screws. Also ran thw b44 plastic hubs. It thought traction would be poor but the truck cornered well. The rear was more planted than I would have thought possible. I started with no weight and battery forward. But I was traction rolling and it did not turn well. It was pushing lol. I added 1/4 to the rear triangles, 1/2 behind the tower and 1oz under the foam. Truck felt good but I think I was slower with the weight. Felt sluggish. My 2 cents
Old 11-10-2012 | 07:37 PM
  #1672
Tech Prophet
Originally Posted by tom_chang79
Ditto. That's why I have seven 1/2oz weights behind the battery! The SC10 washes out too much.
Regarding the SC10B, any of you guys planning on converting yours to it? I might just get the body kit and the tires and wheels for a "buggy" feel...
I plan to convert
Old 11-10-2012 | 10:21 PM
  #1673
IRM616's Avatar
I have lots of wheels for my sc10 4x4. Will they fit the Sc10 too ? Thanks
IRM616 is offline
Old 11-11-2012 | 07:24 AM
  #1674
Tech Prophet
yep. same offsets.
Old 11-11-2012 | 09:42 AM
  #1675
1buzz1's Avatar
can anyone post a picture of a front swaybar set up for sc ten
1buzz1 is offline
Old 11-11-2012 | 10:23 AM
  #1676
mxracer458's Avatar
Looks like ill be running a sc10 for a couple of races,since I used to run buggy,my two lipos are shortys,for the guys that tried them did you soften up your oil and springs or play with ride height?i know in my worlds buggy it was fast and dialed with the shorty.looks like Kevin Motter was running 72/26 in 17.5 blinky.what does everyone else run in blinky?i run at weatcoast and other higher bite wett clay tracks
mxracer458 is offline
Old 11-11-2012 | 11:51 AM
  #1677
drolmaeye's Avatar
4x4 uses hexes, but the original and FT SC10's (at least when I bought mine 18 months ago) use a pin in the back and bearings up front (so I, for example, have three types of wheel to outfit my two SC10s). The new SC10RS comes with hexes as standard. So all of this to say, you may need to change over to hex wheel mounts depending on the vintage of your SC10.
drolmaeye is offline
Old 11-11-2012 | 03:15 PM
  #1678
MD's Avatar
MD
SC10 sway bars.
http://www.nitrohouse.com/product.as...FYpFMgodLT8ArA
MD is offline
Old 11-11-2012 | 03:25 PM
  #1679
Tech Prophet
are they even useful outside of carpet?
Old 11-11-2012 | 03:57 PM
  #1680
MD's Avatar
MD
I would say yes.
MD is offline
