NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 10-24-2012 | 05:07 AM
  #10066
Originally Posted by vitomon
is there any website were v3 settings are collected?
We are in the process of doing this at the moment, if there's anything specific you need, let me know
chris_dono is offline
Old 10-24-2012 | 05:11 AM
  #10067
Originally Posted by puma303
sameone cna help me to find a good setup?
my car is a hot bodies tcx, motor is a lipotech xr 10.5T and the esc is the 120A V 2.1
up
puma303 is offline
Old 10-24-2012 | 05:15 AM
  #10068
nnick's Avatar
Shop Owner
I have gathered some here
nnick is offline
Old 10-24-2012 | 03:54 PM
  #10069
i am thinking about buying a hobbywing esc for 1s oval racing. is there a performance difference between the 120a 1s esc or the new v3 esc?
thanks
dms888 is offline
Old 10-24-2012 | 07:31 PM
  #10070
Richards Racing's Avatar
Default Help
Just installed an xtreme stock esc in my sons car when I hooked up the program box it comes up with dashes and thats all doesn't do nothing even leaving it for in excess of 1 minute. Did install one in another car the other day and didn't have a problem.
Any ideas.
Noel
Richards Racing is offline
Old 10-24-2012 | 11:06 PM
  #10071
ScottyTC4NZ's Avatar
13.5t Open Timing is needed
ScottyTC4NZ is offline
Old 10-26-2012 | 07:22 AM
  #10072
Shev's Avatar
...and 17.5
I have spent hours trying to find a starting point for stock. It would be nice to dial in from there. If anyone can point me in the direction of 17.5 (Australia) settings - I'd be grateful.
Shev is offline
Old 10-26-2012 | 12:28 PM
  #10073
Barry_Hughes's Avatar
...and 17.5
It does help if you post what motor and ESC V2 or V3 - the settings can vary depending on the motor & ESC you are running.
Barry_Hughes is offline
Old 10-26-2012 | 02:27 PM
  #10074
TeamWTF's Avatar
Any ideas.
Noel
Hook it up to your PC and try flashing it.
TeamWTF is offline
Old 10-26-2012 | 02:33 PM
  #10075
TeamWTF's Avatar
Originally Posted by Shev
...and 17.5
(using latest software for v2.1)
Start 3000-4000
Boost 40
Turbo 24
timing acc 250-350
turbo ramp 12
delay 0
Gearing... 5.0 (Large) - 6.5 (Small)
For Logan (Never been there only seen pictures) try 5.0-5.5 (Looks pretty big/open)
Phill
TeamWTF is offline
Old 10-26-2012 | 08:04 PM
  #10076
ta04evah's Avatar
Default Thanks
Would just like to put out a big thanks to Angelo for his help, support and goodwill with Hobbywing products.
The service that a friend and I received went above & beyond our expectations.
I've been very happy with Hobbywing products and will positively recommend them to others.
Cheers
Rob.
ta04evah is offline
Old 10-27-2012 | 12:26 AM
  #10077
Shev's Avatar
Start 3000-4000
Boost 40
Turbo 24
timing acc 250-350
turbo ramp 12
delay 0
Phill
Thanks Phil. It's good to see what other people are using.
Shev is offline
Old 10-27-2012 | 12:31 AM
  #10078
Shev's Avatar
Cheers Barry. I totally agree, but it would still be great to have a library of settings with all the info like Tekin does. You could match something up that is reasonably close to what you use and go from there.
I've just bought a V3. I had my V2 going very well with a revtech. I was hoping to try the revtech and the lrp x12 17.5 with the V3 on a medium/large track with plenty of tight corners. So, top speed and punch is the target.
Thanks for your help fellas, it's much appreciated.
Shev is offline
Old 10-27-2012 | 01:46 AM
  #10079
V3 with SP 3.0 13.5t
Old 10-28-2012 | 12:02 PM
  #10080
could somebody explain the throttle punch function? i am running modified 4,5 and 5,5 motors and cant get those settings right...
vitomon is offline
