SC10 Thread Part 2
#1486
Ive run several different 17.5 motors, and If you want the best 17.5 motor then the speed passion MMM is the best way to go, but the motor has set timing built into the sensor board, so you have to switch the boards out to adjust the timing. The revtech is a great motor but has a lot of timing already built into the motor and runs hot if you turn the can timing up.
My personal recommendation is the reedy sonic. It runs cool throughout the motor timing range. It's the motor I run in my ft SC10, set to 42 degrees can timing and geared 28/75. After a 5 min qualifier or main the motor is about 145-150 degrees. I run in an indoor clay track with a 110+ foot straight.
#1489
You running the RPM or MIP? I think you meant MIP. If so, Try 35wt.(yellow springs) in the front and 30wt (try Batch 1 yellows or batch 2 red) in rear. That heavy weight in front was to accommodate for summer heat (110*F) and the MIP piston which is equal to AE#2. But with cooling temps, go with 35wt. Plus, shock location is critical. If you move the shock out, it will require less wt. oil.
One follow up - you are still talking about LOSI oil weights, right?
#1490
#1495
Anybody have trouble with the 12mm hex conversion when tightening the wheel nuts ??? It seems when I crank down the wheels especially in the front the rim moves the hex in compressing the bearings and making the wheels not spin great? I do have one shim in there but still doesn't help ?
#1496
#1499
I need help. I'm going to be racing my Associated SC10 2wd RTR stock electronics for the first time next weekend. So, I only have this coming weekend to practice.
Need advice on outdoor clay, medium bite with lots of dust in the corners. Fairly smooth track with one medium length straight-away and one short straight away, has one medium jump and 3-4 smaller ones. Fairly short for an outdoor track. About 610 ft total track length.
So, tell me what you guys would run.
#1500
24Likes
