RC10B4.1 FT/WC
Old 10-20-2012 | 08:20 AM
  #22636
Waflet's Avatar
Originally Posted by morkendi
So i picked up a used b4.1 in trade with a lip sxxx v2 and peak racing 7.5 turn with a 50c 5000 mah lipo. Redid all the shocks and went through it real good. Ball diff felt notchy to me, so I tore it down to look. Everything looked good, so I cleaned it with motor spray. Sanded the rings, cleaned again. Put it back together and oiled tranny with some 25 weight shock oil. Tranny runs smoother, but the diff itself still feals really gritty. If I hold a tire while on a stand, it diffs fine with throttle, but still doesn't feel right working diff by hand. First 10th scale buggy because all i have raced before is nitro 8th scale. I am used to gear diffs. Watched building and tuning ball diff videos and don't see where I went wrong. Any suggestions? Everything else working great after cleanup.
Hideeho
Its hard to diagnose with out spinning it my self. You mention using 25wt shock oil, but not clear or black grease. You are using clear grease on the dif balls & black grease on the thrust balls & the 25wt to lube the gears, right? If you are not using clear & black greese I would recommend rebuilding, again, & using it. If you are using greece, & probably even if you aren't since you got the buggy used, replace all the dif balls & thrust balls.
Everyone on here will tell you a different combination of balls is the best. My recommendation is get the cheapest balls you can for the 1st rebuild or 2 & get extras (you will need them learning to set a ball dif up). Once you learn to set up the dif, experiment with carbide & ceramic for dif & thrust to find what combo work best for you.
Waflet is offline
Old 10-20-2012 | 09:12 AM
  #22637
jmc5313's Avatar
Anyone using gear diff in B4.1? I run it in my SC10 and like the reliability. My buggy is still very fresh so no issues yet from ball diff...but when i do have an issue i am considering going to gear diff.
jmc5313 is offline
Old 10-20-2012 | 10:27 AM
  #22638
tom2tone's Avatar
Hey guys...new to the thread here..
I just picked up a new b4.1 worlds kit. I've got a painter doing the body and its taken longer than expected. What seems to work better, the Proline +8mm body or the JC finnisher/ punisher body? I'd like to order one or if anyone is getting rid of one by next weekend.
Thanks!
tom2tone is offline
Old 10-20-2012 | 11:13 AM
  #22639
Matt Trimmings's Avatar
Thanks!
I prefer the JC bodies, go with the finnisher.
Matt Trimmings is offline
Old 10-20-2012 | 11:30 AM
  #22640
t0p_sh0tta's Avatar
Depends on where you're racing. I like the look of the bulldog, so i went with that.
t0p_sh0tta is offline
Old 10-20-2012 | 11:41 AM
  #22641
YankeeFan123's Avatar
Thanks!
Finnisher
YankeeFan123 is offline
Old 10-20-2012 | 02:16 PM
  #22642
Thats what video says. Said heavy grease can bind tranny. Use a light oil like shock oil.
Okay. Thanks! I'll soon be going to ball diffs in my buggy and SC10.
shagnat is offline
Old 10-20-2012 | 03:01 PM
  #22643
Wild Cherry's Avatar
If you use any lube, oil, grease , Pledge, ect ?
you will risk contaminating the diff lube and ruining the diff .
Just use the clear silicon diff lube on the gears or nothing at all ....
Waflet Hideeho
Sorry did not notice you flipping the c-brace .
Not sure about that flipping that part though .
The camber link position will not be stock and each camber position longer .
You have changed the geometry of the link ....
Would avoid changing and why the BB shock
instructions advise to do as suggested .
Shimming the shock changes very little , changing the camber link positions is big .
Wild Cherry is offline
Old 10-20-2012 | 05:12 PM
  #22644
JB_catricala's Avatar
Waflet Hideeho
since he is still using the same hole on the tower the geometry has not been changed becasue it is still the same perpendicular distance from the outer hinge pin.
just like if you were to change the front outer ball ends on the front of the schumacher svr to a straight end and extend the ball stud, the camber link would be shorter compared to distance of the two ball studs before the change. or like the old jconcepts ends that cleared the rims under exteme movement, the link was techincally longer if you travelled the length of the camber rod but it wont affect the geometry.
the only way this could effect geometry is if the arms were pivot ball suspension. then the postion would effect castor change and other things.
JB_catricala is offline
Old 10-20-2012 | 05:14 PM
  #22645
BIGSKI15's Avatar
Does anyone have close up pics of cars from the associated drivers that have big bores? Its hard to believe that they would run the car if the springs hit the turn buckles under driving conditions. I'm going to run the car with a flippped c tower and with associated's recommendations to see if there are major handling differences due to the slighly changed geometry.
Its hard to swallow paying $100 for something that is going to be rubbed down to bare metal because there isn't an absolute mounting solution. I would rather see a b4.2 rather than a B5 so that I can simply update anything related to mounting the shocks so they aren't rigged plus,my car would still be considered current...lol
BIGSKI15 is offline
Old 10-20-2012 | 05:56 PM
  #22646
Big Features's Avatar
If you build/install them per instructions, there is no issue. I did swap the plastic spacers for 2mm and 1mm AE ballstud shims.
Big Features is offline
Old 10-20-2012 | 07:07 PM
  #22647
ryanpatrickgore's Avatar
Mine I'd done per instruction as well.
No probs
ryanpatrickgore is offline
Old 10-20-2012 | 07:28 PM
  #22648
romian14's Avatar
Anyone know a good gearing for a Revtek 17.5t Motor? with a Tekin rs?
romian14 is offline
Old 10-20-2012 | 07:32 PM
  #22649
try 35/72....... run for 3 minute and test temp.
Bob Barry is offline
Old 10-20-2012 | 08:05 PM
  #22650
Default bb, no flip
Here's a close up. No rubbing, no tower flip.
Attached Thumbnails RC10B4.1 FT/WC-2012-10-20_19-56-53_643.jpg
associatevalley is offline
