RC10B4.1 FT/WC
Old 10-15-2012 | 01:57 PM
  #22336
Wildcat1971's Avatar
Tech Prophet
Originally Posted by Asharus
the stock ballstuds were long enough for me to put a nut on the bottom threads below the u-brace. i've seen some guys that run the shaved brace where their ballstud pulled out of the brace because there's less material for the ballstud to grab onto. the only thing is that it will be a pain in the ass to take the ballstud out if i need to add/remove washers or move it to the outside hole.
maybe put a washer underneath too to spread the force? might help give the shaved brace a little more strength and yes adding/removing washers will be a pain. that is the main reason I never did it. But I am eating u braces like candy.
Wildcat1971 is offline
Old 10-15-2012 | 02:01 PM
  #22337
Asharus's Avatar
nah, the ballstud just barely had enough threads to grab onto the nut i used below. the nut i used looks exactly like the bottom set on this pic.
Asharus is offline
Old 10-15-2012 | 02:04 PM
  #22338
Tyler Keel's Avatar
I think that was in reference to the avid A/C tower.
Yeah, that was my thinking also, broken studs in the alum brace. The plastic ubrace is trash. I wear those out after 2 weekends. I either strip the hole, rip the stud in half or rip a chunk out of the brace. The weekend I stripped out the hole. The stud was not staying tight, I had to re-tighten after every heat and it just work it out. I like the carbon, but it normally breaks after shaving. 8th scale large jumps ftw. Plus you have to factor in my driving, lol. Might try putting a nut under the brace on the ball stud to prevent the stripping.
Carbon brace is the way to go. I also haven't had a problem with my Avid towers breaking, and I don't use a spacer.
Tyler Keel is offline
  #22339
Tech Prophet
well just think, with the nut on, if you rip the brace apart, you wont lose the washers.....
Old 10-15-2012 | 02:08 PM
  #22340
Tech Prophet
yeah, I bought a new carbon brace last week in anticipation of mine not lasting long. Still need to shave it though.
Old 10-15-2012 | 03:55 PM
  #22341
trickedyfz450's Avatar
I picked up a set of the 12 BB shocks this past week. I am very disappointed! The finish on my rears are terrible. The one cartridge has a small spot that it looks the finish was rubbed off. That I can deal with.. The bigger problem is the rears also seem to suck air from the bottom. I ran the car for about 3 minutes then the rear got real loose. I pulled the springs and checked rebound to fine that they are now rebounding all the way out. I built them with normal rebound and the exact way the paper says. I also used green slim on the red orings. My fronts are fine with no problems. I spoke with our local team driver and he is having the same problem and has since switched back to the standard v2's. is anyone else having these problems??
trickedyfz450 is offline
Old 10-15-2012 | 03:59 PM
  #22342
I got the new 11mm Squib Bore shocks. TK helped me in the testing. They are DIALLEEEEEED
Bob Barry is offline
Old 10-15-2012 | 04:00 PM
  #22343
MikeFriery's Avatar
did you build them at the track?
MikeFriery is offline
Old 10-15-2012 | 04:02 PM
  #22344
Tech Prophet
Huh
Old 10-15-2012 | 04:06 PM
  #22345
Not initially but once I seen them doing this I tore them down to make sure I did them right then rebuilt them there. Same effect
Old 10-15-2012 | 04:26 PM
  #22346
MikeFriery's Avatar
Somethings not sealed.. make sure your cap o ring isn't bunched up and all the seals are in place.. i wouldn't run the bleeder screw o-ring.. none of the AE guys do.
Old 10-15-2012 | 04:31 PM
  #22347
savannahmick's Avatar
I run on a outdoor loose track with med. jumps and have ran a SC10 FT and B4.1 for a couple years and never broke a u-brace but did snap one stock ballstud once and snatched a couple shock screws out on arms thats it so I don't know how you guys are braking these braces might need to limit up travel or down travel on shocks. Anyway I have old carbon braces with no raised area are they the same except that? Also I use the tiny Losi gold nuts on bottom of ballstud on brace and c-hub tower. Good Luck!
savannahmick is offline
Old 10-15-2012 | 05:17 PM
  #22348
onefast8's Avatar
Why are some people running the plastic front pin brace over the blue alum. one?
onefast8 is offline
Old 10-15-2012 | 05:20 PM
  #22349
ShtLuck's Avatar
Saw this happening this weekend......
the air has to be coming in on compression, thus from the bottom seal or there would be oil pushing out the top under compression. If it was an upper seal the compression would push the oil out. The shocks are dry on the outside, but building air volume inside the oil raising the rebound.
ShtLuck is offline
Old 10-15-2012 | 05:27 PM
  #22350
Eli's Avatar
Eli
For how little o-ring stiction there is i can care less if i have to top off my shocks before my main. Im assuming the air is coming up past the o-rings and increasing pressure in the shocks but its not enough for me to fiddle around with o-rings quite yet. I get barely any seepage from my o-rings and they perform great on the track. I will service my shocks before my qualifiers then before my main i will take the caps off, add a little bit of fluid then bleed them like normal and set them to zero rebound. Did i mention these shocks are butter smooth?
Eli is offline
