RC10B4.1 FT/WC
Installed and ran the BB's this weekend. Went the extra mile and completely ground down both towers. Guys you should at least grind the rear tower down. This way your shocks will be straight up and down...springs will NOT rub the bodies, or the little blue cartridge caps. The shocks did NOT leak either. I did use a 1mm blue spacer with the bottom rear eyelets to keep the springs off of the tie rods too. Man they are smooth as silk !
so I broke an a arm this weekend, no biggie right. So I bought a new set and wow, wtf. The arms that came with my WC were nicely made. smooth and did not require tooling to make them free. These replacement arms are well, crap. Sharp molding all over the place. I filed and dremeled them and they still are not free. if I lift the arm with the tire and shock off, and release...it stays up. I will keep removing material until its free, but what happened? Did AE get a new molding company?
The A and B hubs are the same height. The holes on the B are in between the holes on the A (or vice versa).
Hey Mick, when our track is that way, it's hard to get grip. You just have to learn to drive it that way to be honest. It's not an 1/8th scale.
However, I've been told Holeshots and Bowties work well when the track is that way. I've bought a set and plan to try them. We'll compare tires some this weekend.
Otherwise, the other gentlemen is correct. If the diff feels bumpy, rebuild it. It has to be smooth. Rebuild it by the instructions exactly!
even check the hinge pin brace if its binding the arms....that also has happened to me even when i just bottomed out the 2 screws, if so add a small spacer.
The back of the tower...under and around the inside upper mount hole. My buddy spaced his out, and after 1 race day the back of his shock bodies and the blue caps were scratched up some. I did no cap spacing, just tower grinding, and mine did not scrape anything...thankfully.
I would get rid of the calibers and rebuild the diff. The diff should feel smooth with out a gritty feel. Should feel absolutely smooth. 2wd buggies are VERY diff sensitive. I have never felt calibers on any track has been the "fast" tire to run. If the surface is loose/dusty, maybe double dees, ifmar pins, maybe 3ds. look at what the fast guys are running in 2wd as well. I would bet 95% of the problem you are having is tires and the diff.
The B4.1 Parts List page shows long ball studs for the rear hubs of the B4.1 on page 8.
I'll post again what happens with AE after I head over there hopefully later this afternoon.
