RC10B4.1 FT/WC
Old 10-07-2012 | 12:56 AM
  #21691
Wild Cherry's Avatar
Originally Posted by OptimumRC
Oh....no, you need to use the LONG shock bushing with 1mm spacer and its dialed!
The short vs the long short bushing is like 2mm difference...so that would be an extra 2mm of grinding so I'm not surprised it broke!
correct and what I posted to do for a stronger tower ...
factory drivers are use the short bushing
Wild Cherry is offline
Old 10-07-2012 | 01:07 AM
  #21692
OptimumRC's Avatar
Oh...I guess I don't remember ever saying to use the short shock bushing, but glad you got it sorted.
I have yet to have even the slightest issue with this setup.
OptimumRC is offline
Old 10-07-2012 | 06:07 AM
  #21693
tedstryker's Avatar
Have broken two ft towers after grinding to fit BB .
To use the original shock position you have grind quite bit off the ft tower.
Makes for a weaker part and now know from experience you guys might like to use something stronger .
Now use the longer FT shock bushing(#1781) & a .030 shim behind it .
You will have to shave very little for the shock to clear & makes for a lot stronger tower & a happier racer ....
Rear tower seems to be strong enough to handle the trim , no breaks from the rear tower yet ...
Funny i mentioned this about 2 weeks ago how the front tower will become weaker..and people harped on me about it...
O well looks like you found a fix for it for now...
I'll stick to my K shocks ...
tedstryker is offline
Old 10-07-2012 | 09:21 AM
  #21694
Shaving it is only bad if you crash a lot
PFKAOG is offline
Old 10-07-2012 | 09:32 AM
  #21695
Getting back into 2wd after running 1/8e all summer. Just bought a b4wc kit and gonna start out w chad dues setup as thats what most local guys ate running here indoors. Seems shorty packs are the norm too. Do i wanna mount my esc behind the shorty pack or just on the lt side like normal? Hope to have it all ready to go for next weekend.
nitro0619 is offline
Old 10-07-2012 | 10:01 AM
  #21696
Why I recommended a stronger set-up to you guys as most will crash occasionally.....
Old 10-07-2012 | 11:30 AM
  #21697
new to AE b4.1 buggy, what is the +8mm chassis, and what about the b44 rear arms and rear u-brace shaved. Can some one tell me about this stuff? thanks
bring it on is offline
Old 10-07-2012 | 12:23 PM
  #21698
+8mm chassis is just that a chassis that is 8mm longer than the old b4. B44 arms are arms that were included with the b44 (4x4 version) that are a bit stiffer.
Shaved U brace just knocks off the raised area where the rear camber links attach to to change the roll center and camber gain
jdeadman is offline
Old 10-07-2012 | 12:29 PM
  #21699
Thanks, so then the worlds b4.1 already has that chassis then? I thought I heard some guys saying they where running a T4 truck chassis.
Old 10-07-2012 | 12:50 PM
  #21700
CHIZZLE's Avatar
I'm confused about the whole shaved u-brace thing. If you lower the inner point by shaving the brace and then lower the outer by using the C tower, you're just lowering the link completely. Wouldn't the roll center be the same?
I thought roll center is related to putting an angle on the camber link, meaning you move one side or the other, higher or lower.
CHIZZLE is offline
Old 10-07-2012 | 01:14 PM
  #21701
Matt Ward's Avatar
I thought the b44 arms are a soft plastic causing them them to provide better rear traction.
Matt Ward is offline
Old 10-07-2012 | 01:15 PM
  #21702
B.A. Racer's Avatar
no..b4.1 is the softest..b44 are stiffer..and carbon is the stiffest
B.A. Racer is offline
Old 10-07-2012 | 01:27 PM
  #21703
Matt Ward's Avatar
OK thanks for clearing that up
Old 10-07-2012 | 01:31 PM
  #21704
OptimumRC's Avatar
No, that is incorrect. The roll center is determined by extending an imaginary line from the upper camber link and the lower control arm (if you draw a line through the hinge pins) until the two intersect. This is called your instant center (IC) and is the imaginary point in which the wheel, camber link and arm rotate about. Then drawing a line from the center of the tires contact patch to the instant center, and doing this for both sides of the car and the point in which the these two lines intersect is your roll center.
When you lower the upper camber link it is essentially like drawing another parallel line under the original location and as a result the IC changes since the lines intersect sooner and thus the line from the tires contact patch is even steeper and therefore actually raises the RC slightly.
One thing to keep in mind is that this only determines the 'static' roll center, but when the chassis rolls through a turn the roll center migrates around and how much it moves is influenced by the suspension geometry.
Heres an image that I just googled that should hopefully help illustrate what I said:
Old 10-07-2012 | 01:38 PM
  #21705
Eli's Avatar
Eli
Lowering the whole link lowers the roll center.
Eli is offline
