Like Tree3Likes
Mugen MBX6
Old 10-05-2012 | 03:19 PM
  #17791
IRM616's Avatar
whats the best servo for this buggy??
IRM616 is offline
Old 10-05-2012 | 03:59 PM
  #17792
BigNasty's Avatar
1268 savox is pretty badass and affordable. The ko are great, too, for twice the money. hitec 7955, 7950 also good. I have them all, and like the savox best at either steering or throttle
BigNasty is offline
Old 10-05-2012 | 04:11 PM
  #17793
IRM616's Avatar
perfect. is that the best savox for it?
thanks again
IRM616 is offline
Old 10-05-2012 | 10:59 PM
  #17794
I have 6r eu spec and 6r us spec. It's a complete diffrent feel one to another.
What is the diffrent beside white carbon, light weight axle, and +1+2 hub?
The eu spec is easier to drive. It has alot of traction even in very loose track.
Is there any diffrent in the crown and pinion gear in us spec? I havent count it yet but u will later. The chassis is it the same? Thanks
yollie is offline
Old 10-06-2012 | 03:27 AM
  #17795
Have used Savox 1267's for the past couple of years, been very reliable. One did die on me, so have retired the working one to the spares box.
Currently using Hitec 7945's, very impressed with them so far a lot of my mates swear by them.
Chris-s is offline
Old 10-06-2012 | 04:37 AM
  #17796
thanks again
i switched from 1267/1268 to brushless 2273. you will never look back !
for mugen also change to truggy servo safer spring (silver) you will gain steering & less fading in long finals.
gt racing is offline
Old 10-06-2012 | 06:51 AM
  #17797
just got these bad boys in yesterday....
o.s. power is offline
Old 10-06-2012 | 08:37 AM
  #17798
shaidi khalid's Avatar
the eu spec chassis has 2mm setback..as i know..and yeah..the eu spec rocks..
the hubs are use to add stability n steering
shaidi khalid is offline
Old 10-06-2012 | 01:55 PM
  #17799
TRF415boy's Avatar
EU Spec chassis is the same overall length, but everything between the 2 gearboxes has been moved back by 2mm. The front centre driveshaft is longer to make up for this.
EU Spec also uses the 42/12 internal ratio (crown/bevel) instead of the 44/13 (MBX6/6R/6R US).
Last difference is ther rear tower has an extra outer row for the rear link.
TRF415boy is offline
Old 10-07-2012 | 12:02 PM
  #17800
revo61's Avatar
Has anyone used the M2C hinge pin system? Do they help performance and make the car easier to work on?
http://racemugen.com/catalog/m2c-mug...del-p-204.html
revo61 is offline
Old 10-07-2012 | 12:11 PM
  #17801
MadRussian's Avatar
Yes been using them for years, great stuff! Make it quite a bit quicker to work on also!
MadRussian is offline
Old 10-07-2012 | 01:24 PM
  #17802
Keith Lewis's Avatar
Highly recommend the M2C system for front and rear. A lot easier to work on and very durable. Almost 2 seasons of racing on it with not one bent hinge pin.
Keith Lewis is offline
Old 10-09-2012 | 12:15 AM
  #17803
HI TRF415
You have said a few times you think the EU chassis is better, as opposed to changing to a EU chassis do u not think a similar weight balance could be acheived with a US +5 chassis by moving the RX battery, or adding some weight in rear ?
Will
WillF is offline
Old 10-09-2012 | 12:52 AM
  #17804
TRF415boy's Avatar
Originally Posted by WillF
HI TRF415
Will
No you cannot, because even if it may be the same mass balance in static, it is not the same dynamically.
Old 10-09-2012 | 02:40 AM
  #17805
BigNasty's Avatar
Can anybody tell the difference? Really....
just busting your chops lol
I love in the us, and run the us spec, and it's been awesome. I'm sure the eu spec would also be awesome. As to where each would be optimum... Who the hell really knows. They are really really close imo. It's 8th scale, not on road.
BigNasty is offline
