SC10 Thread Part 2
#1352
Well, tested out the new BB's and they are definitely an upgrade. The truck was much more planted and even when I missed the backside of a jump, it was butter...
I know they are pricey, but they are worth it.
#1353
my buddy has them on his ride.. next time i go to the track i will take a pic for ya.. he loves them.. night and day difference in performance he's claiming.. but i've been waiting it for the new BB's so we will see whats better in the near future
#1354
I'd end up giving them away trying to sell the SC10 4x4 anyway, just about have to pay someone to take it off my hands.
#1355
#1356
Thanks Borack and cnt wait to see em, I have a tuning question guys. My setup is this
40wt ft oil
Piston 3
Losi 22t green spring
6 limiters
30 mm ride height
Inside on tower
Outside on arm
Link inside 2mm washer on tower
A hole on caster
30 deg caster
Knuckle with washer under
1/4 oz in ft triangles
30wt oil rear
Piston 2
Losi bb 22t white
29mm ride height
3 limiters
4th drill hole on tower
Inside on arm
3 onboard toe
.5 deg hub
Shaved ubrace/ c hub
3oz under batt foam/ ballast under tranny
Med wheelbase
What I'm trying to accomplish here is to eliminate some more of that body roll, I took away some by moving the ft shocks out on the arm and going from piston 1 in rear to #2 and that helped but I wnt to take out more and also gain a lil bit more rear traction when I punch it out of corners. Can I get a lil tuning help from the gurus? Lol
40wt ft oil
Piston 3
6 limiters
30 mm ride height
Inside on tower
Outside on arm
A hole on caster
30 deg caster
30wt oil rear
Piston 2
Losi bb 22t white
29mm ride height
3 limiters
Inside on arm
3 onboard toe
.5 deg hub
Med wheelbase
#1357
No, I kind of went with my own setup based on my current setups.
Front: 35wt AE oil, 5 limiters, 1.5 piston & Avid yellow spring (3.48 lbs.) with short cups.
Rear: 30wt. AE oil, 1 limiter, 1.6 piston & Avid yellow spring (Batch 1 @ 1.99lbs.) with medium cups.
I did use the shims that were provided because I didn't want to shave the towers. The shims actually move the springs away from the camber links with no ill effects.
At first I thought the front felt way to soft, but went ahead and tried it. Nope, they were perfect. These things sucked up the bumps and were so plush on flat landings with no bounce.
#1358
40wt ft oil
Piston 3
6 limiters
30 mm ride height
Inside on tower
Outside on arm
A hole on caster
30 deg caster
30wt oil rear
Piston 2
Losi bb 22t white
29mm ride height
3 limiters
Inside on arm
3 onboard toe
.5 deg hub
Med wheelbase
40wt ft oil
Piston 3
6 limiters
30 mm ride height
Inside on tower
Outside on arm
A hole on caster
30 deg caster
30wt oil rear
Piston 2
Losi bb 22t white
29mm ride height
3 limiters
Inside on arm
3 onboard toe
.5 deg hub
Med wheelbase
You can try 3mm on the front camber link. Highlighted in red in you quote. If your in a testing mode, try moving that same ball stud to the out side hole on the shock tower to give it a shorter camber link. Just something to try. Note how it feels and see if it will help or not.
The rear had a huge effect on the truck as well. I've made some changes in the rear that made it more stable but loose. It's kind of a trade off.
I've been playing around with setups lately and they I'm pleased with the results. Some times they work, sometimes not.
#1359
#1360
The shims move the springs away from turnbuckles.
#1361
Much appreciated.
For those that don't have the AE or Avid springs - TLR big bore springs fit nicely and to mimic this setup, or even AE's the TLR Silvers are 3.4in/lb and the TLR Yellows are 2.0in/lb.
#1362
Can someone recommend a good servo for the SC10 rs 2wd? We bought the rtrs and are looking to replace the servo soon. The cheaper the cost the better, but I understand not throwing money away, and perhaps going a bit more $ for a much better servo I would consider also...TIA.
#1363
#1364
If you are looking to do things on the VERY cheap - http://www.hobbypartz.com/125g.html
But if you are looking to do it right get a Savox 1256 on the for sale section for ~$50 and never worry again.
#1365
24Likes
