Like Tree2991Likes
1/12 forum
Old 09-19-2012 | 09:18 PM
  #38311
jarrodh's Avatar
Originally Posted by tr1kstanc3
What's the pros and cons of moving the battery in my Xi forward/back? Which position is most popular for blinky?
just different weight split f/r..
battery forward would give more oversteer in, and less forward grip on the power.. battery back, would make it less twitchy/ tighter into the corner, but would have more drive and more stable off corner
jarrodh is offline
Old 09-19-2012 | 09:26 PM
  #38312
chris moore's Avatar
Originally Posted by Csaari77
13.5 was chosen to conform to what other tracks in the area are running. I agree 17.5 would be easier to learn with, but I think that ship has sailed. To give you an idea about the size of the track, 17.5 blinky TC is turning 8.0-9.0 laps. The track is on the small size but they keep the layouts fairly flowing and open.
Wow
chris moore is offline
Old 09-20-2012 | 05:34 AM
  #38313
wingman2's Avatar
A couple of the guys at our local club are trying 17.5 blinky, and although it is slower than 10.5, it does require a differant type of driving style to go quickly. After watching them go around, I don't know if it's 'easier' to drive or not to be honest!
wingman2 is offline
Old 09-20-2012 | 08:43 AM
  #38314
Csaari77's Avatar
Originally Posted by LonnyJ1950
If you decide to use an RX pack, I've tried several and had the best results with the Revtech LIFE 250 MAH pack.
I've got one on the way! How many runs do you normally get out of it, or do you just charge it every run?
Csaari77 is offline
Old 09-20-2012 | 08:55 AM
  #38315
EricF's Avatar
You can easily get 2 runs, maybe even 3, but it's best to charge after every 2 full runs.
E
EricF is offline
Old 09-20-2012 | 08:58 AM
  #38316
CypressMidWest's Avatar
Battery forward decreases weight transfer front to rear under acceleration and deceleration which in general settles the car down. The car will rotate more quickly through the corner with the battery in the rear position. Rear battery position will offer more steering off power, and square up quicker on-power leaving the corner. It will also have a slightly greater tendency to traction roll due to the increase in weight transfer.
Most set-ups for big races have the battery forward due to the high level of grip afforded by large turnouts. A car can benefit greatly from moving the battery back on club tracks with less grip.
CypressMidWest is offline
Old 09-20-2012 | 05:59 PM
  #38317
LonnyJ1950's Avatar
E
+1 If you go for that 3rd heat you're rolling the dice. Eric can tell you, I've died in the middle of a couple of heats.
LonnyJ1950 is offline
Old 09-20-2012 | 06:06 PM
  #38318
RedBullFiXX's Avatar
imo
Very accurate description
RedBullFiXX is offline
Old 09-21-2012 | 03:59 AM
  #38319
FaanP's Avatar
Hi,
We only run 1/12th mod here South Africa. I would like to know if a 6000 mAh battery with a C-Rating of 45C will be good enough for anything between a 4Turn - 5.5 turn motor?
F
FaanP is offline
Old 09-22-2012 | 01:12 AM
  #38320
Hey Everyone,
Ive got a xray X12 and Im having traction issues and doesnt seem to accelerate straight either.
The track I run on is ashphalt which low traction and a little bumpy.
Setup is standard with 7.5T motor. Tyres are Xceed soft rears and Medium fronts.
Im willing to get new springs and shock oils.
Just want to be put in the right direction before I get anything
Any help will be appreciated!
Cheers
Kevin
HBRC-LBD is offline
Old 09-22-2012 | 03:05 AM
  #38321
silvalis's Avatar
I had a similar issue on my X12. I wound up balancing the chassis and pod separately on pins, then putting them together and balancing again.
Whats your setup?
silvalis is offline
Old 09-22-2012 | 03:49 AM
  #38322
V12's Avatar
V12
Someone remember the first CRC cars using rear wheels of the old 2 hole system? Did CRC have their own wheels that time? Any pictures?
V12 is offline
Old 09-22-2012 | 11:09 AM
  #38323
Csaari77's Avatar
I just got my Rectech pack and I have a question about charging it. It comes with 2 leads, and one looks like a balancing plug. I assumed this is a 1s pack, so why a balance lead. Can I still charge it using the receiver plug?
Csaari77 is offline
Old 09-22-2012 | 11:19 AM
  #38324
It is a two cell pack.
Yes you can charge it through the receiver plug.
AreCee is offline
Old 09-22-2012 | 12:27 PM
  #38325
Hey Silvalis,
Setup is all stock at the moment just played around with weight to try make it better.
Are associated springs compatible with the X12?
Cheers
HBRC-LBD is offline
