rc8be and puffed lipo's :(
So i am lost here. I have a rc8be with a mamba monster 2200kv setup. The gearing is 15 46. I was running 2 newer (always balanced charged) Trak power 5600mah 60C packs on the street. After about 5 min i stopped and both packs were puffed. The motor temp was 150F and the esc was not hot.
I checked the lipo's cell voltages battery 1 had cell voltage of 3.93 and 3.94 and the other lipo had cell voltage of 3.97 and 3.98.
With the temp being around 150 i thought i was good. was i under geared?
thanks for any help here, Joe
P.S i just recharged 1 of the lipos it took 1387 mah and finished with cell voltages of 4.204 and 4.206
I agree that it is more than likely too high a draw. Running on concrete/carpet provides alot of traction and will result in a higher draw than running on dirt or grass.
You seem to have decent batteries so this is kind of perplexing.... Were the lipos warm? How many cycles are on your batteries? Ever puffed before?
try gearing down for bashing and rolling the throttle, the motor is going to demand the most amps with tall gearing and full throttle, if you can ease that it will work the batteries less. You should temp the batteries too.
