rc8be and puffed lipo's :( >
Old 09-03-2012 | 03:59 PM
Questions?? rc8be and puffed lipo's :(
So i am lost here. I have a rc8be with a mamba monster 2200kv setup. The gearing is 15 46. I was running 2 newer (always balanced charged) Trak power 5600mah 60C packs on the street. After about 5 min i stopped and both packs were puffed. The motor temp was 150F and the esc was not hot.
I checked the lipo's cell voltages battery 1 had cell voltage of 3.93 and 3.94 and the other lipo had cell voltage of 3.97 and 3.98.
With the temp being around 150 i thought i was good. was i under geared?
thanks for any help here, Joe
P.S i just recharged 1 of the lipos it took 1387 mah and finished with cell voltages of 4.204 and 4.206
jjcmx05 is offline
Old 09-03-2012 | 05:18 PM
so i recharged one of the lipos and it took 1387mah and cells ended at 4.204 and 4.206
jjcmx05 is offline
Old 09-04-2012 | 01:07 AM
You should run with a timer like 5-6 min.
A lipo don t like to be full discharged. It may be cause your "puff"
Manson is offline
Old 09-04-2012 | 01:29 AM
Suspended
It might be too much of a load for your batteries to handle.
Huggy Bear is offline
Old 09-04-2012 | 06:45 AM
hotrodchevy14's Avatar
I agree with huggybear...my buddy has a losi 4x4 sc and it has puffed 2 packs.
hotrodchevy14 is offline
Old 09-04-2012 | 06:56 AM
mkiiina's Avatar
3.9v is no where near low voltage cut off and even further from complete discharge.
I agree that it is more than likely too high a draw. Running on concrete/carpet provides alot of traction and will result in a higher draw than running on dirt or grass.
You seem to have decent batteries so this is kind of perplexing.... Were the lipos warm? How many cycles are on your batteries? Ever puffed before?
mkiiina is offline
Old 09-04-2012 | 09:38 AM
Packs had about 10 cycles on them. It was fresh blacktop the car was hooking up great.its going to be on a clay track. So guess i can just hope it was the blacktop that caused it.
jjcmx05 is offline
Old 09-04-2012 | 10:33 AM
MikeXray's Avatar
try gearing down for bashing and rolling the throttle, the motor is going to demand the most amps with tall gearing and full throttle, if you can ease that it will work the batteries less. You should temp the batteries too.
MikeXray is offline
Old 09-04-2012 | 11:59 AM
It may have been the at battery did go much lower than that but then recovered by the time it was measured. A high load will also cause low voltage.
ixlr8nz is offline
Old 09-04-2012 | 01:13 PM
guess The answer is to keep the car for the track and off the street. lipos are to expensive lol
jjcmx05 is offline
Old 09-04-2012 | 01:23 PM
Suspended
Just change your gearing depending on what kind of driving you are doing and you should be fine.
