Like Tree21Likes
New LRP Flow Esc
Old 07-30-2012 | 05:41 AM
  #46
liteweight's Avatar
Default after 3 laps speedo stop and no lights at all
Guys im 1st time user of lrp, I have a lrp tc spec last Saturday im practicing after 3 laps the car stop I check the Speedo there is no light at all, try to reset it still no power,any solution on this .thanks
liteweight is offline
Old 07-30-2012 | 02:57 PM
  #47
Try plugging a receiver pack into the receiver and see if it lights up then. The BEC has been the culprit on these things. Had this happen with a new one right out of the box some time ago.
Andy Koback is online now
Old 07-30-2012 | 06:37 PM
  #48
liteweight's Avatar
just tried it and still no light
Old 07-30-2012 | 06:53 PM
  #49
Are you using the switch on the receiver pack and not on the ESC? Some have had the switch on the ESC go bad too. As a last resort, cut the switch off and twist the 2 wires together on the speedo. Only way to shut it off is to disconnect the main battery pack. If these 2 things don't work, then something inside took a dump.
Old 07-30-2012 | 07:23 PM
  #50
liteweight's Avatar
Thanks for the help but still didn't work, i have read some thread about the bec issue of it, not a good experience with lrp , i've been using Tekin before swithching to lrp now im ending up going back with my Tekin, well i guess that what it is, Im just one unhappy customer
Old 07-30-2012 | 08:06 PM
  #51
bhambrent's Avatar
Try here http://www.rctech.net/forum/electric...rsion-2-a.html maybe someone in the sxx forum can tell you what's going on with it.
bhambrent is offline
Old 07-30-2012 | 08:14 PM
  #52
I had this problem with 2 diffierent units. Sent it back!
M3CSLDreamin is offline
Old 07-30-2012 | 11:41 PM
  #53
Stusdal's Avatar
I have been using LRP for some time and it gives way better feel then anyting i ever tried, and they are so easy to get right. The FLOW probably won't be any worse.
However, I have had two sxx die on me over a polarity mistake - how hard can it be to build in protection for this?
I'll try out ORCA VX now, but will keep an eye on how the FLOW is treating people.
Stusdal is offline
Old 07-31-2012 | 02:00 PM
  #54
Originally Posted by NolanP
Sounds like you should trade me a speedo for my rs pro.....
I'll trade you my stock spec for the rs if you dont mind sending to Denmark :-) I will gladly cover the expenses :-) PM me if your interested.
Kind regards Chris
mrtoulouse is offline
Old 07-31-2012 | 02:55 PM
  #55
I had the understanding that when the BEC fails, it will work with a receiver pack. Mine did. Gotta be something else. I went back to Mamba!
Old 08-11-2012 | 08:01 PM
  #56
I am running a tc spec v2 with a Revtech 8.5 can anyone help with settings /gearing for 2wd sc10
Fvann is offline
Old 08-21-2012 | 12:45 PM
  #57
The new FLOW's are coming soon, but wich one do I need for 1/12 modified with LRP 3,5 and 4,0 motors with worksteam rotors ... I think the worksteam version but used without the fan.
Any advise?
Best wishes; Jens
jensroland is offline
Old 08-21-2012 | 01:55 PM
  #58
My understanding is that it's not hard, it just increases resistance and thus reduces power.
-Mike
grippgoat is offline
Old 08-21-2012 | 11:42 PM
  #59
Any advise?
Best wishes; Jens
You should use the WorksTeam Version. I've seen a few pictures of drivers using the fan behind or in front of the speedo at the worlds.
kind regards
Marcel
Marcel is offline
Old 08-29-2012 | 01:18 AM
  #60
Julius's Avatar
Any advise?
Best wishes; Jens
I ran a works team flow at the 1:12 world championship without fan. Esc temps were no issue at all. Keep in mind the flow does need a receiver battery or booster to work on 1s.
As a nitro racer i need all capacity for the motor anyway so the receiver pack helps
Julius is offline
