RC10B4.1 FT/WC
Old 08-24-2012 | 02:57 PM
  #19261
CraigMBA's Avatar
That's true - the thrust bearing is crap on the AE. My only complaint with the 4.1 platform, really.
CraigMBA is offline
Old 08-24-2012 | 03:06 PM
  #19262
Wildcat1971's Avatar
Tech Prophet
I thought the ceramic thrust balls were bad
Wildcat1971 is offline
Old 08-24-2012 | 03:12 PM
  #19263
DesertRat's Avatar
I guess they forgot to tell me. Unless I have a catastrophic failure I won't be going back to metal. I would order more of them but they don't seem to wear out.
DesertRat is offline
Old 08-24-2012 | 03:19 PM
  #19264
ryanpatrickgore's Avatar
Savox is power hungry but it's not the problem. The problem is spectrum receivers. I run all Savox and no issued with airtronics or futaba. Unlimited problems with spectrum.
There Im done with Stevo talk...
ryanpatrickgore is offline
Old 08-24-2012 | 03:24 PM
  #19265
Tech Prophet
What lube are using? Stealth lube on diff and AE grease on the thrust
Old 08-24-2012 | 03:33 PM
  #19266
DesertRat's Avatar
Only the best AE silicone diff grease, in both the diff and thrust bearing, no black grease at all.
Old 08-24-2012 | 03:37 PM
  #19267
B.A. Racer's Avatar
use black grease on your thrust..AE diffs are one of the best out there...
B.A. Racer is offline
Old 08-24-2012 | 03:39 PM
  #19268
aeRayls's Avatar
Thats definitely the issue. Use the black grease on the thrust.
aeRayls is offline
Old 08-24-2012 | 03:41 PM
  #19269
Tech Prophet
New question. I have tried to build my shocks with rebound. But cant seem to do it with the bleeder caps. Any ideas?
Old 08-24-2012 | 03:43 PM
  #19270
DesertRat's Avatar
I used to use black grease in the thrust, it made no difference as the thrust bearing was crunchy and the diff still felt bad, now i have full silicon nitride balls in the thrust bearing, so it doesn't matter.
Old 08-24-2012 | 03:44 PM
  #19271
B.A. Racer's Avatar
I used to use black grease in the thrust, it made no difference as the diff was still bad, now i have full silicon nitride balls in the thrust bearing, so it doesn't matter.
it matters big time..run carbide diff balls and ceramic thrust..Silicone in the diff and black grease on your thrust balls...make sure you set it and break it in also
Old 08-24-2012 | 03:47 PM
  #19272
DesertRat's Avatar
I did break it in, and it works great. No reason to take it apart just to switch to black grease in the thrust bearing.
Old 08-24-2012 | 03:48 PM
  #19273
Eli's Avatar
Eli
And how long has it been in there for?
exactly what i do, Bfast pro diff kit FTW!
Eli is offline
  #19274
mxracer458's Avatar
What size are the diff balls
mxracer458 is offline
Old 08-24-2012 | 03:50 PM
  #19275
B.A. Racer's Avatar
3/32"
