Losi 1/8 8ight E 4wd Thread
#7996
Does Losi sell the 8ight-e plastic spur without the metal insert for a cheaper price than the two together? Doesn't make a lot of sense to keep buying the metal insert over and over.
http://www.amainhobbies.com/product_...pur-Gear-8E-20
#7997
#8000
THE OTHER DAY I SAID I WOULD BE SELLING BOTH MY 8IGHTS, WELL I THINK I HAD A BRAIN FART, I WILL BE KEEPING BOTH OF THEM AND GET ANOTHER NITRO LOSI 8IGHT. I WAS NOT THINK STRAIGHT!!! I WILL BE STAYING WITH LOSI!!
#8004
so 46/14 = 3.29 which makes your buggy slower if all other things remain the same.
Ratio's are usually compared the other way though 15/45 = .333
and 14/46 = .304 , now 16/48 = .333
Motor are rater per kv so a 1900kv motor turns 1900rpm per volt , 14.4v battery = 27360rpm
27360 with 15/45 (.333) = 9111 rpm
27360 with 14/46 (.304) = 8317 rpm
8713/9111 = .956 and roughly 4% slower but will have 4% more torque
#8005
thanks for reply. Im just getting sick of stripping the 45 tooth plastic spur. I have a metal 46 tooth is the reason for me asking, and dont wanna buy the 45 tooth metal one lol. Im clueless to why I keep stripping the spur, I have the mesh just right. On other buggies that used plastic spurs I never stripped one. Just with the losi Im having issues.
#8006
I was going to take mine off till I notice how much the motor mount and center diff support would tweak if you apply pressure to the motor by hand.
I have 4 weeks on my kit and it gets run hard 2/3 times a week. STill on the same spur.
I did set the mesh as close as possible and still have some play.
#8008
Is it getting warm? I've seen people's center diff get really hot, hot enough to start melting the spur and the pinion destorying it.
#8010
