Losi 1/8 8ight E 4wd Thread >
Old 07-25-2012, 06:05 AM
  #7846
Trader Rating: 37 (100%+)
Originally Posted by SUPERLOOPER View Post
I really didn't think soft packs would hold up to the abuse of a 1/8 car. I should have done some research on batteries. Oh well! Thanks for the info guys.
Brian
I got my 6s packs with my 8 buggy and they were used. I must admit they have seen better days and when it comes while to replace ill probably get hardcase.
slyts6 is offline
Old 07-25-2012, 10:56 AM
  #7847
dangerwr's Avatar
Brian
This is my 4th year running soft packs in my car and race most every weekend! The trick is using some industrial strength velcro--hooks in the battery tray and a generous strip of loops on the battery. Dialed. They are lighter too!
dangerwr is offline
Old 07-25-2012, 11:19 AM
  #7848
Good tip with using velcro in the battery tray! I never thought of doing that. My next pack may be a soft case as well.
jha07 is offline
Old 07-25-2012, 12:57 PM
  #7849
dangerwr's Avatar
Yeah, I would personally run velcro on hard packs as well to keep them from sliding around. I punched out the front of my battery tray once with a soft pack once and never again after using velcro. I line the entire width of the battery tray with the hook (stiff) side of the velcro. And then I cut the loops (soft side) to about half the width of that battery and center that strip for the entire length of the battery. Does that make sense?
dangerwr is offline
Old 07-25-2012, 07:02 PM
  #7850
Gene158's Avatar
Can anyone tell me how to remove the center outdrive from the center diff? It's on my e-converted 8ight T. I know it's kind of a stupid question but I bought the truggy used and I'm still trying to figure this truck out. The flange bearing on the front side disintegrated and I need to replace it.
Gene158 is offline
Old 07-25-2012, 07:42 PM
  #7851
dangerwr's Avatar
Not a stupid question but believe you answered your own question~you need to remove the outdrive to take off that bearing. If you need to replace a bearing on the center outdrive (happens often BTW!) you will need to remove the spur first . . . it all comes apart from there . . .
dangerwr is offline
Old 07-25-2012, 07:45 PM
  #7852
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
it should be a small set screw on the end of the shaft...
BlackStarRacing is offline
Old 07-25-2012, 08:14 PM
  #7853
Gene158's Avatar
It's on the side opposite the spur. In the manual, I dont't see any set screw. I just see the bearing and outdrive cup which apparently is held on by a pin but I can't access the pin.
Gene158 is offline
Old 07-25-2012, 08:25 PM
  #7854
Monteman's Avatar
Trader Rating: 16 (100%+)
Too bad the weather here recently has been more geared to boating...
But finally finished my new build.
Monteman is offline
Old 07-25-2012, 08:31 PM
  #7855
Gene158's Avatar
Actually my center diff is a smart diff if that makes a difference.
Gene158 is offline
Old 07-25-2012, 08:34 PM
  #7856
Monteman's Avatar
Shouldn't, just means more parts inside the diff.
4 screws to remove the spur, it comes out with the out-drive cup. once its out you take the gear off and the pin is under that gear. then you can remove the diff-cup and replace the bearing.
Monteman is offline
Old 07-25-2012, 08:49 PM
  #7857
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Does the smart diff work like a one way or do you still have 4 wheel braking?
UN4RACING is offline
Old 07-26-2012, 01:34 AM
  #7858
can someone tell me if this pack is on its way out or if its already clapped?
i got 2 of these 4000mah 20c 6s flightmax in the sale with my 8ight and I'm not sure if they are rats--t....
this was after 15mins of bashing and speed runs. running a 1350kv t8 rx8 system and gears 45/20... temps are 140f for motor and 100f for esc....battery was 120f.
slyts6 is offline
Old 07-26-2012, 03:43 AM
  #7859
Trader Rating: 21 (96%+)
looks like its time for a new lipo
john stu is offline
Old 07-26-2012, 06:44 AM
  #7860
Gene158's Avatar
Yes I still have 4 wheel braking. To be honest with you, I couldn't tell you the performance difference between the smart diff and the stock diff. I bough this truck used with the smart diff already installed.
Gene158 is offline
