Like Tree5Likes
SC10 4x4 Thread
Old 08-05-2012 | 12:36 AM
  #27916
murky123's Avatar
our truck, does it has the same offset as the losi SCTE ?
murky123 is offline
Old 08-05-2012 | 01:25 AM
  #27917
BorackBasher's Avatar
Lots of things to try
tires
ride height (lower rear)
lighter rear spring, lighter oil & less rear camber..
start with tire & ride height ( 23mm low as you go )
what if tires and ride height are correct and it still wants to come swing around in front?
BorackBasher is offline
Old 08-05-2012 | 03:55 AM
  #27918
Smithy79's Avatar
Hey guys,
Those running the 8mm mod on the rear camber links... what length are your turnbuckles? (between cups, like in the manual instructions ?mm).
I'm running mine inside hole on shock tower, and outside hole on the fibre c-hub mod.
Cheers.
Smithy79 is offline
Old 08-05-2012 | 06:46 AM
  #27919
Originally Posted by Smithy79
Hey guys,
Cheers.
I am running 7mm, outside hole on rear tower, and outside hole on c-hub riser which lines up with inside hole on hub. Also running short camber link in front with 1mm shim under front ball stud. 2.0mm sway bars front and rear. Blue front spring front and white front spring in rear. 32.5 front shock fluid, 27.5 rear, single x-ring, bladder, no boots, 6mm ext. limiters. Front shock middle hole tower, outside on arm. Rear shock inside hole on tower and arm. V2 C-diff with 5 pins, 7k front diff and 5k rear. FT ackerman rear holes. Exotek chassis, 23mm ride height. Tazer wheels on 3mm offset hazard wheels run on med traction outdoor track, wet to drying.
F_ME is offline
Old 08-05-2012 | 08:41 AM
  #27920
Wild Cherry's Avatar
Hey guys,
Cheers.
measured 5mm
between the ball cups
inside on tower & outside on C hub
Wild Cherry is offline
Old 08-05-2012 | 08:52 AM
  #27921
Smittydidit's Avatar
Hey Smithy, I run mine inside on the tower and inside on the c hub bracket.Inline with the inner hole on the stock rear hub carrier just 8MM higher
Smittydidit is offline
Old 08-05-2012 | 08:53 AM
  #27922
Wildcat1971's Avatar
Tech Prophet
Borak. I was able to get mine to do what I wanted by using a lower bite tire up front. It really helped calm the truck down. So far the sway bars and the lower bite tires up front, have helped me the most.
Wildcat1971 is offline
Old 08-05-2012 | 08:55 AM
  #27923
well i run barcodes all around on my indoor track.. maybe try stock tires up front for a push?
Old 08-05-2012 | 08:56 AM
  #27924
Matt Trimmings's Avatar
Maybe a Double Dee
Matt Trimmings is offline
Old 08-05-2012 | 09:00 AM
  #27925
+1 on the Barcodes @ OCRC. Perfect tire for that application
Old 08-05-2012 | 09:01 AM
  #27926
Originally Posted by Matt Trimmings
Maybe a Double Dee
dont have any double dee's.. what about a holeshot? all i really got is stock's at the moment.. not sure if i want to spend the extra 30 bucks for another set of tires
Old 08-05-2012 | 09:04 AM
  #27927
Borak, What is the surface your running on?? Other Than OCRC?
  #27928
Tech Prophet
ok, well i raced last night. The truck ran night and day better than any other time I ran it. Rotated the right amount in the corners and squared up well. I actually really enjoyed the truck. I ended up TQ'ing and winning with the truck. He is the basics of my setup.
Front:
locked clicker
Over Drive 19t pulley
Yellow springs
Camber link inside with 5mm
shocks top center and bottom outside
2 oz lead to the left and right of the servo
FT Ack in the rear holes
Arms Level
AE Team Kit Tires
1/2 oz left front and stick pack
2.2/yellow sway bar
32.5 wt oil
1.2 piston no bladders
rear
front blue springs
NO 8mm mod
Zero camber shims
Camber link middle hub and outside on tower
Shock Middle top and inside bottom
2.0/Blue sway bar
27.5 weight oil
Exotek Front Slipper Locker w/ VTS Outside Sliper
15/62 gearing with a Tekin 550 2 pole 4.5 motor
Proline Sniper Tires.
arms just below level
I went from last place last week to TQ. It was way better.
Old 08-05-2012 | 09:06 AM
  #27929
Are you going to install the team set-up ?
Old 08-05-2012 | 09:10 AM
  #27930
Congrats!! Wildcat Great feeling to have the truck work the way you want it to
