Like Tree5Likes
SC10 4x4 Thread
Old 07-26-2012 | 08:02 AM
  #27136
BorackBasher's Avatar
rear. i think the front position is the same as the non option.
Borak, what was your setup when people told you your truck looked hard to drive?
30k in the front 5k in the rear.. zero washers front and rear on the inner ballstud. yellow springs all around.. 1.2 pistons all around 32.5 in the front 27.5 in the rear 8mm of bumpsteer washers 7mm in the rear on the outside of the shock. 3-2 block. shocks middle hole front and rear on the top.. i think outside bottom hole in the front and inside hole in the rear on the bottom.. running saddle packs.. sxx tc spec v2 with a tekin 4 pole 4600.. gearing is 62/13.. profile settings.. 3 - 1- 3 - 1. ride height is 24 all around.. i think thats about it..
BorackBasher is offline
Old 07-26-2012 | 08:13 AM
  #27137
Wildcat1971's Avatar
Tech Prophet
8mm of bump steer? Do you mean external shock limiters? I tried zero washers up from, but it sucked, I am at 5mm right now. With a short front link. Rear is zero washers with inside tower and middle hub for camber link. If I still over steer, then I might try inside on the front tower and just lay that shock down. Also, have you slowed down your servo? That was pretty huge for me, my fast servo made the truck undrivable.
Wildcat1971 is offline
Old 07-26-2012 | 08:16 AM
  #27138
yea bump steer external washers... i have an xp 1313 and its super fast.. if i put 5mm inside hole on the front what will that do to the truck? and leave the back at zero
Old 07-26-2012 | 08:20 AM
  #27139
Evil Genius jr.'s Avatar
Just to clarify. Bumpsteer is washers under the outside steering link. Bumpstop is on the shock shaft.
Evil Genius jr. is offline
  #27140
Cain's Avatar
what oils have some people gone to that are different than Mantis stock Center Diff setup he has out (using his pistons)
Cain is offline
Old 07-26-2012 | 08:21 AM
  #27141
I'm as 25/22.5 AE (22.5/20 LOSI) with blue/Fwhite springs.
Old 07-26-2012 | 08:22 AM
  #27142
oopps sorry.. so currently i have 0 bumpsteer washers and 8mm bumpstop in the rear and 7mm of bumpstop on the front! bent another cva last night too
Old 07-26-2012 | 08:24 AM
  #27143
Cain's Avatar
wow. The front on mine feels right, just seems like the rear is blowing through the oil, very bouncy.
Cain is offline
Old 07-26-2012 | 08:28 AM
  #27144
the main issue im having is the truck is loose in the rear.. cant get it to square up.. when coming onto the straight its hard to get the truck to go straight then the high speed sweeper is always unpredictable.. very loose.. feels like the front is pulling harder than the rear
Old 07-26-2012 | 08:29 AM
  #27145
Wild Cherry's Avatar
[QUOTE=Evil Genius jr.;11019634]I'm as 25/22.5 AE (22.5/20 L
Hows that working for yeah ?
Wild Cherry is offline
Old 07-26-2012 | 08:34 AM
  #27146
Good but I have the two-stage pistons. Stock I like 32.5/27.5.
I know I know stay AE but the 2-stage pistons really helped on my bumpy track.
Old 07-26-2012 | 08:38 AM
  #27147
Not sure bout the piston , but the rear spring seems awfully stiff .
Do you still have good grip & steering ?
Old 07-26-2012 | 08:42 AM
  #27148
double post
  #27149
I actually still push a little, but it jumps and accelerates amazing. I did some math and found a couple balanced spring combos:
Yellow outside/ FBlue inside
Blue outside/ FWhite inside
White outside/ FGreen inside (way to soft but you get the idea)
I feel a balanced spring makes the car overall just better.
Old 07-26-2012 | 08:45 AM
  #27150
Tech Prophet
It should take away steering in the front and calm it down. You are also running the short camber link in the front right? That servo is not quite as fast as mine, but still plenty fast, might wanna try to slow it down. It made a massive difference for me.
