SC10 4x4 Thread
30k in the front 5k in the rear.. zero washers front and rear on the inner ballstud. yellow springs all around.. 1.2 pistons all around 32.5 in the front 27.5 in the rear 8mm of bumpsteer washers 7mm in the rear on the outside of the shock. 3-2 block. shocks middle hole front and rear on the top.. i think outside bottom hole in the front and inside hole in the rear on the bottom.. running saddle packs.. sxx tc spec v2 with a tekin 4 pole 4600.. gearing is 62/13.. profile settings.. 3 - 1- 3 - 1. ride height is 24 all around.. i think thats about it..
8mm of bump steer? Do you mean external shock limiters? I tried zero washers up from, but it sucked, I am at 5mm right now. With a short front link. Rear is zero washers with inside tower and middle hub for camber link. If I still over steer, then I might try inside on the front tower and just lay that shock down. Also, have you slowed down your servo? That was pretty huge for me, my fast servo made the truck undrivable.
the main issue im having is the truck is loose in the rear.. cant get it to square up.. when coming onto the straight its hard to get the truck to go straight then the high speed sweeper is always unpredictable.. very loose.. feels like the front is pulling harder than the rear
I actually still push a little, but it jumps and accelerates amazing. I did some math and found a couple balanced spring combos:
Yellow outside/ FBlue inside
Blue outside/ FWhite inside
White outside/ FGreen inside (way to soft but you get the idea)
I feel a balanced spring makes the car overall just better.
It should take away steering in the front and calm it down. You are also running the short camber link in the front right? That servo is not quite as fast as mine, but still plenty fast, might wanna try to slow it down. It made a massive difference for me.
5Likes
