8T 2.0
I have gallons on my engines (not sure how many, but new this season) and I can not recall any time that I have started one of them without being on my Competition Heat!!!! I REALLY think it has and will extend the life of my engines, and man...they start up like a dream everytime
Fits: LOSI 8ight Buggy or Truggy
LOSI 8ight 2.0 Buggy or Truggy
LOSI L8 Dirt Oval
FEATURES: This Mount is CNC machined from
7075 aircraft grade aluminum and Black Anodized. These are designed
with a base mount and removable top blocks. Once the mount is installed
in the vehicle and the gear mesh is set you can remove and reinstall the
motor without resetting the mesh.
Another new feature is be flipping the top blocks from front to back you can
move the motor forward 2mm. This will allow you to run a standard 3 clutch
shoe setup without using an excessive amount of shims.
The extended arm is secured through the existing fuel tank hole in your chassis
so you do not have to drill any new holes.
Extra mounts can be purchased separately so that other motors
can be swapped out quickly.
++ Mount can not be used with Roto or Pull start motors ++
INCLUDES:
(1) Base Mount
(1) Set of top blocks
(1) Fuel Tank Post
(1) 5-40x 1/2" Alloy Flat Head Cap Screws
(8) 5-40 x 1/2" Alloy Allen Head Cap Screws
(4) M3 lock washers (used with screws that hold the top blocks to base)
SPECS.
Material: 7075 Aircraft Billet Aluminum
Weight: 35.83 grams (base, fuel post and 2 top blocks - no hardware)
Instruction Link: KPI-215
Hardware Kit Link: KPH-030
They give you a tank post with the mount.
No holes needed, the only thing kingheadz made where you needed to drill a hole was the extended rear brace.
Correct, it just bolts right up. I'm not sure what the other two are talking about.
mine is several years old and i had to tap a hole. That's all i am saying i believe it was for a RC8. I do see the fuel tank post with this one. Just decide if you want the extended or not. I am not crazy about the losi quick change mount.
Well that's the problem, it was far a RC8. The kingheadz mount comes with everything needed, no drilling needed. Please don't confuse people when comparing the losi to a AE product.
