RC10B4.1 FT/WC
http://teamassociated.com/pdf/cars_a...Reedy_Race.pdf
hey guys.
i am new to the buggy world. typically race SCTs but now switching over to buggies and just setup a B4.1 FT.
am wondering, are there any forums dedicated to the B4? this one is just one giant running thread all about the B4...seems kinda all-over-the-place? i am unable to locate a site where we can setup individual threads on each topic...helps quite a bit...anyone know of such a place for the B4? if not can we request it from RCTech?
thx.
-RC tomato
thx.
-RC tomato
hey guys.
thx.
-RC tomato
thx.
-RC tomato
Kuya
hey guys.
thx.
-RC tomato
thx.
-RC tomato
I want to try the BB Spring setup, but.... My rear turnbuckles are already realy really close. How are you guys keeping the rear springs from rubbing on the rear turnbuckle? I am using lundsford punishers btw.
Need some help tuning my buggy. I just installed a RCRD +8 Chassis. The Chassis gave the car a ton more steering but I have lost some rear traction. I have trouble entering the turn coming off the streight it just wants to spin out. Forward traction is also less. I need to get this buggy hooked up in the rear. Here is my setup that worked very well with the old chassis. Let me know what you think I can change to hook up the rear a bit better.
FRONT
Camber: -1/2
Shocks: 1top 0bot
Camber Link: 1A w/ 2 Washers
Toe: 0
Ride Height: 24mm
Axle Height: Middle
Caster: 30
Bump Steer: 2mm
Shocks: Avid Yellow springs. 35 wt. AE Oil #2 piston 3 limiters
REAR
Camber: -1
Shock: 1top 1 bot
Camber Link: B1 with no washers.
Wheel base: short
Ride Height 23mm
Shocks: Avid Red Springs #2 Piston AE 30 wt. oil 2 limiters
TOE: 3degree with 2 degree anti squat
FRONT
Camber: -1/2
Shocks: 1top 0bot
Toe: 0
Ride Height: 24mm
Axle Height: Middle
Caster: 30
Bump Steer: 2mm
REAR
Camber: -1
Shock: 1top 1 bot
Wheel base: short
Ride Height 23mm
TIA
Its the same u brace. YOu just take a dremel to it and grind it flat underneath the ballstud. I believe the C Hub is a spare included in the kit.
