Like Tree5Likes
SC10 4x4 Thread
Old 06-27-2012 | 05:04 PM
  #25696
Evil Genius jr.'s Avatar
Just get the FT, Center diff, pistons.
Evil Genius jr. is offline
Old 06-27-2012 | 05:09 PM
  #25697
RCManiac007's Avatar
Originally Posted by obsoletex
Need some advice.
If my plan when I buy the sc10 4x4 is to buy the:
rc shox ackbar
stg shock mod
center dif v2
Kyosho BB velvet shocks
Would it be sensible if I just got a used standard edition?
With the standard kit you wouldn't get the brace or the saddle cradle.
RCManiac007 is offline
Old 06-27-2012 | 05:11 PM
  #25698
Wild Cherry's Avatar
Need some advice.
rc shox ackbar
stg shock mod
center dif v2
Buy a Team , you really do not need to buy anything else cept a body , tires & rims ...
Wild Cherry is offline
Old 06-27-2012 | 06:57 PM
  #25699
bschanz's Avatar
Default factory team conversion
hey guys, i just made the ft conversion for saddles. i moved the rx to the right side of the truck but wondered where people are putting the rx antenna? I i have mine (mxsport) strapped to the belt tunnel. any insight?
bschanz is offline
Old 06-27-2012 | 07:17 PM
  #25700
Wildcat1971's Avatar
Tech Prophet
swap your esc and reciever
Wildcat1971 is offline
Old 06-27-2012 | 07:23 PM
  #25701
obsoletex's Avatar
I like the FT version of my b4.1 but I do not own nor want to buy any saddlepacks that only fit one car when I have many.
obsoletex is offline
Old 06-27-2012 | 07:30 PM
  #25702
bschanz's Avatar
wildcat, i tried that, but there is not enough vertical clearance to get the esc with fan under the belt tunnel. i am okay with it the way it is. it just looks a little shoddy!
ben
bschanz is offline
  #25703
ilanstylz's Avatar
The FT SC10 has the option to run saddles or stick so you can still use the lipo's you already have........
ilanstylz is offline
  #25704
The FT can be configured either way. Stick or saddle. If your set on putting your mwntioned parts on the truck and you don't want saddle's then I say go ahead and pick up a used standard kit for cheap and put the stuff on that you want. You can always get the chassis brace on e-bay for cheap..
Old 06-27-2012 | 07:43 PM
  #25705
This works good. Just drill a small hole, just big enough to get an antenna tube into. Put a drop of ca glue on it and your good to go. Looks like it was meant to be there.
Old 06-27-2012 | 07:44 PM
  #25706
Simple green and lemon pledge.
jamr1130 is offline
  #25707
dakotafroader's Avatar
Just an FYI for the guys not wanting to go to saddles because they won't "fit"..... I run mine in my SC10 and b4.1, you just line them up end to end. In reality... It gives you a whole different weight placement option if you put the foam inbetween the cells
dakotafroader is offline
Old 06-27-2012 | 07:48 PM
  #25708
Tech Prophet
ben
I have seen people drill a hole on the right reart and mount an antenea, but I guess you was work for you
Old 06-27-2012 | 08:31 PM
  #25709
AErckidd's Avatar
I'm going to be getting my first SC10 4x4 and I have a question. Can I just run my normal 2s LiPo's that I run in my 2wd SC10? Does the size fit? I know this seems like a dumb question, but I've never run anything 4x4. I've just seen that nearly everyone does the saddle pack conversion, so I wasn't sure. Thanks for the help.
AErckidd is offline
Old 06-27-2012 | 08:36 PM
  #25710
Tech Prophet
Yeah, you can use stick packs.
