Like Tree5Likes
SC10 4x4 Thread
Old 06-22-2012 | 08:20 AM
  #25441
Originally Posted by twisted
yea my plastic hexes took a dump on me. the hex part didnt strip but the inner "race" on the side that faces the bearing melted. might be form tightening the wheel to tight. regardless they are being replaced.
Same thing happened to me my first night out. Get the Aluminum hexes and you won't have any issues.
Snafujg is offline
Old 06-22-2012 | 10:20 AM
  #25442
darryl80's Avatar
do the shock limiters go in between the spring cup and the shock rod end?
darryl80 is offline
Old 06-22-2012 | 10:23 AM
  #25443
You want the limiters above the spring cup and below the bottom of the shock.
Krio is offline
  #25444
No, above the spring cup.
Arakon is offline
Old 06-22-2012 | 10:24 AM
  #25445
Wildcat1971's Avatar
Tech Prophet
Above the cup and below the rubber bumper. Count the rubber bumper as part of the 8mm. I think mine was 3mm thick, thus 5mm of limiters.
Wildcat1971 is offline
  #25446
samuelsonmark71's Avatar
No, on top of the shock cup. Should be: Shock cartridge - limiters - shock cup
samuelsonmark71 is offline
Old 06-22-2012 | 10:34 AM
  #25447
drolmaeye's Avatar
Four answers within a minute or so only a few minutes after the question was asked . . . let this thread be an example to the others.
drolmaeye is offline
Old 06-22-2012 | 10:43 AM
  #25448
and no one told him to use the search function....bravo...oh i didn't realize you count the bumper in with the 8mm thanks for that info,no wonder my travel is so limited....lol
beaven is offline
Old 06-22-2012 | 10:50 AM
  #25449
Wild Cherry's Avatar
Really bad example to tell someone to go search ..
Lots of new racers that need help , telling someone to read the entire thread or search is just being negative & lazy ...
Lots of good folks here and they try to be helpful ....
Wild Cherry is offline
Old 06-22-2012 | 10:54 AM
  #25450
darryl80's Avatar
so the go on the shock shaft above the spring cup and under the shock boot?
darryl80 is offline
Old 06-22-2012 | 11:15 AM
  #25451
I put mine in the shock boot
Old 06-22-2012 | 11:20 AM
  #25452
Default vts vs c-diff
Hey guys i am wondering does the exotec/vts setup provide more acceleration than the v2 c-diff. It just seems that i am not getting all i can out of my c-diff. Maybe i just need to replace the spring not sure what to do. Thanks
mckenzies is offline
Old 06-22-2012 | 11:22 AM
  #25453
darryl80's Avatar
I put 5mm on each shock would it hurt to put another 1mm on each shock to use up the rest of my limiters?
darryl80 is offline
Old 06-22-2012 | 11:46 AM
  #25454
Cameron Kellogg's Avatar
Depending on your traction level at your track the VST slipper might give you more rear drive off the corners. With that said yesterday I was testing a new motor in front of my house before heading to the track and I was pulling the front wheels off the ground a few inches with 6 pins in the center diff. So that is pretty much maximum drive to the rear without flipping over backwards.
The pins do wear over time so you might try turning the pins a little to make contact in a new spot on the ball.
Cameron Kellogg is offline
Old 06-22-2012 | 12:06 PM
  #25455
ilanstylz's Avatar
So how many limiters is everyone putting on their front and rear shocks and are you using the stock ones that come with the kit or are there better ones out there?
ilanstylz is offline
