Like Tree5Likes
SC10 4x4 Thread
Old 06-19-2012 | 08:30 AM
  #25246
Wild Cherry's Avatar
Originally Posted by CraigMBA
Craig
problem I have seen mounting the fan or fans like the picture shows is the chassis flexs then breaks the fun blades..
Not sure if you have tried yet , just wanted to share my experience when I mounted fans as shown ...
Wild Cherry is offline
Old 06-19-2012 | 09:10 AM
  #25247
Oasis's Avatar
Originally Posted by JLinney
A few months ago there was no need for those shims Cherry. You change your mind more than my wife. You are 100% correct on one thing though. I do not have a clue, what you are talking about. You are such a tool bro. Now back to your regular programming.
Now that was funny..
Oasis is offline
Old 06-19-2012 | 09:35 AM
  #25248
Vegatron75's Avatar
Only been using Ae pads...
Been cleaning all three VTS pads after every 15 runs or so.....
Could go longer but oil from the diff seeps in though top shaft.
Oil main reason I have to clean ...
You only need to test ride my truck Coyote.....
That's all it would take ....
linney , you have no clue , I would notice lack of pull after 2 turns ...
Well you did asked how i would know ?
Pardon
I can't resist teasing old guys
Don 't even try until you have the new diff shims ....
Will be building one for myself next week ....
and
not really that much of a "tuff guy" ,I just punch it ....
Coyote , hope your blessed & around to make that post as well ....
JLinney
JUST CALM DOWN
Said do not use any extra shims , assemble diff as the instruction show .
Have fun with the names & attacks , won't respond to any of that crap....
Dude, What is the deal w/ you and the enter button?
Why all the space between the priceless advice?
Makes the post bigger?
Overcompensation?
Lay off the AE fanboy stuff
We are all well aware that your rig is top notch, all ae, and bad ace....
Finally saw a video of you racing, didn't look bad, but surely wasn't killing it.
back it down a notch.....
Vegatron75 is offline
Old 06-19-2012 | 09:50 AM
  #25249
Vega
I love hogging band width
Love Ae
Sorry I did not impress you with the run , I was not either ...
Old 06-19-2012 | 10:15 AM
  #25250
TEAM-AE-4-EVER's Avatar
Hey, for those using the VTS Slipper w/ the Garodiscs from Marcus along with the Exotoek Inner Hubs (ilanstylz, Grouchman and any others), can you explain why the combo works so well? Also, from the pics I have seen of these Exotek Inner Hubs, is it one plate for the Rear and one for the Front?
Lastly, what type of tracks do you race on with this set-up?
Thanks!
TEAM-AE-4-EVER is offline
Old 06-19-2012 | 10:29 AM
  #25251
Grouchman's Avatar
Thanks!
I race at Westcoast Raceway, which is 100% clay, med-high traction, indoor track. Exotek doesn't make a front system. I'm using the VTS Slipper w/Garodiscs from Marcus along with the Exotoek Inner Hubs. The Exotek inner hub removes the inner disc with a solid plate. Truck feels like the pin mod, lots of rear traction. I'm digging it right now.
Grouchman is offline
Old 06-19-2012 | 10:35 AM
  #25252
ilanstylz's Avatar
Grouchman got it right on the dot, the exotek is only installed on the inner part of the spur with the vts going on the outside. I had great success with the v1 diff and for some reason I kept having issues with my v2, now I know its all on me because I probably didn't install it right. However with the setup I am currently running on an indoor small clay track it seems to working just as good if not better then my v1 diff. If I keep my center diff I may just install it and try it once again and compare it with my current setup but I can honestly say what I'm running now is working out great.......
ilanstylz is offline
Old 06-19-2012 | 11:24 AM
  #25253
Wildcat1971's Avatar
Tech Prophet
That sir is very interesting. Did you have to cut the chassis to mount that?
Wildcat1971 is offline
Old 06-19-2012 | 12:32 PM
  #25254
i can not answer for the other person but i mounted mine like that the other day. you have to cut out a portion of the chassis wall to let the air flow to the motor and drill two holes to mount the fan.
im using a muchmore fan and it took temps down by 30 degrees.
twisted is offline
Old 06-19-2012 | 12:40 PM
  #25255
Tech Prophet
Would something like this work to keep the 540 motor cool? Any issues putting in motor coolers? Space?
Old 06-19-2012 | 12:45 PM
  #25256
Cameron Kellogg's Avatar
I have run my fan that way from day one. Never broke a blade. I killed a couple of yeahracing fans from hard landings over time, but it was just electrical failure with the wiring. Flawless operation from my Murfdogg fan for about 6 months now. It is twice as thick as the yeahracing fan but still moves about the same amount of air.
Cameron Kellogg is offline
Old 06-19-2012 | 12:48 PM
  #25257
I run a Murfdogg 5.5 2pole 540 motor and with the fan I have no temp issues. Start with low ESC timing and work your way up like with any set-up.
Old 06-19-2012 | 12:51 PM
  #25258
Tech Prophet
I have the "cheat" mode turned off in the MMP. No timing. No motor timing. I am not at my home pc, but I think there is punch or toque controls, right? Would I need to change those?
Cameron,
Which fan are you running? The one I linked?
Old 06-19-2012 | 12:53 PM
  #25259
Evil Genius jr.'s Avatar
Thinking off selling my SC10 4x4, I want to try a different class and can only afford one car at a time . Has the following:
Custom saddle pack conversion
Custom chassis brace
8mm mod
RCShox 2-stage pistons
RCshox V2 Center diff
Trackstar O-rings
Sway Bars
Aluminum hexes
RPM Front Arms
STRC Aluminum belt tensioners
A bunch of extras and brand new avid hub bearings.
Diffs correctly shimmed
2 sets of wheels
2 sets of mounted AKA city blocks (one 60%, the other brand new)
2 beat up bodies
2 slightly puffed (still balance and work perfectly) Gens Ace 6000mah 25C saddles
Any idea how much I could get?
Thanks! Hopefully I can stay but I want to try something else with a wing lol.
Evil Genius jr. is offline
Old 06-19-2012 | 12:54 PM
  #25260
I run Tekin ESC. I run 30deg of ESC timing in Dual mode with -5 timing on the motor. Geared 16/93 can run a pack dead with temps under 150 with a fan.
