RC10B4.1 FT/WC
Old 06-01-2012 | 10:22 AM
  #15361
Originally Posted by gamedog1966
I run stock blinky mode and I geared my car down from 34/75 to 33/75 and it seems way to punchy but the acceleration is great for the short run that leads to my douples at the track. I use to to make the jumps with the old gearing but had to swing just a lil wider which often gave up my line for a split second. How should I make adjustments to keep the torqe but keep it smooth at te same time?
What esc?
Using the expo function on the radio comes to mind if you want finesse at low speeds/throttle input.
Krio is offline
Old 06-01-2012 | 10:50 AM
  #15362
Eli's Avatar
Eli
Car is not twitchy, it does what you tell it to do.
Eli is offline
Old 06-01-2012 | 11:09 AM
  #15363
jf+'s Avatar
jf+
+8 body that will fit an MMP under it? Finnisher isn't really right and things get a little hot. Don't want to cut a hole unless I have no other options..
Thanks!
jf+ is offline
Old 06-01-2012 | 11:10 AM
  #15364
bilster44's Avatar
Yeah, I just added alum hub to the rear, so I should really drops some weight. Probably remove the 1oz from behind the rear tower. I just have to pull the tower off to get to it.
You only have to drop the rear t-plate down to get that weight out of there...you don't have to remove the shock tower.
bilster44 is offline
Old 06-01-2012 | 11:29 AM
  #15365
RCmayor's Avatar
Actually just have to unloosen the 2 screws that hold the front block on the rear that you adjust antisquat with. Take those two screws out and that piece pulls forward.
RCmayor is offline
Old 06-01-2012 | 11:48 AM
  #15366
Wildcat1971's Avatar
Tech Prophet
yeah, you right. its right behind the Anti Squat, that would be the easiest. Good call.
Wildcat1971 is offline
Old 06-01-2012 | 11:54 AM
  #15367
Tech Prophet
Thanks!
I have an MMp that I want to use in my buggy as well. But it just will not fit under the body. I wanted to remove the fan, since my esc run cool. I even looked at the instruction on their site to remove the fan, but i swear mine does not have the tab they want me to cut, in fact i am pretty sure mine does not look like their sketch. So i run a 5 year old lrp sphere because it fits and try to gear for speed, since I am basically forced into blinky, lol. I was tempted to mount my esc on the battery strap towards the back, but I could not make myself do that, so much weight up high.
Old 06-01-2012 | 12:28 PM
  #15368
ilanstylz's Avatar
Finally got my B4.1 WC done, now just waiting on my revtech motor to come in so I can take it to the track and start dialing it in.......
Still unsure of the paint scheme but most likely it'll be a blue/red combo....
ilanstylz is offline
Old 06-01-2012 | 12:31 PM
  #15369
D.Martijn's Avatar
Is there anyone who has tried the C hub towers?
Are they much better? I run on loose dirt (qute sandy track) and some parts of the track are carpet/astro
Thanks,
Martijn
D.Martijn is offline
Old 06-01-2012 | 12:54 PM
  #15370
Tech Prophet
Why the bumper?
Old 06-01-2012 | 12:55 PM
  #15371
Tech Prophet
so you got a brushless hobbies esc to fit huh. What body is that? stock kit?
Old 06-01-2012 | 12:58 PM
  #15372
Asharus's Avatar
looks like the stock proline bulldog +8 that comes with the worlds edition
Asharus is offline
Old 06-01-2012 | 01:14 PM
  #15373
ilanstylz's Avatar
Why the bumper?
Why not???????????
And yes it is the stock body that comes with the kit, I also have the jconcept punisher body for it as well and it also fits with the brushless hobbies esc.
Here's another cheap mod that I've done with my FT T4 and it works great:
Its the FT SC10 4x4 VTS slipper setup.....
Old 06-01-2012 | 01:16 PM
  #15374
Asharus's Avatar
because that bumper is for bashers and if you try to downside a jump and nose down too low it will likely get caught on the dirt and cause you to wreck
Asharus is offline
Old 06-01-2012 | 01:21 PM
  #15375
ilanstylz's Avatar
Yes I understand that, however I'm used to 4x4 sct's etc so going back to 2wd buggy is going to be a challenge for me. Once I feel comfortable enough with the buggy it may or may not come off, but for now it stays........
