RC10B4.1 FT/WC
Old 05-31-2012 | 04:05 PM
  #15331
BigJohnRacing's Avatar
Transfer those hop-ups to your worlds
BigJohnRacing is offline
Old 05-31-2012 | 04:08 PM
  #15332
Cheapest way to get to worlds spec:
http://kriostasis.com/store/index.ph...1&keyword=%2B8
http://kriostasis.com/store/index.ph...&products_id=2
http://kriostasis.com/store/index.ph...&products_id=1
http://kriostasis.com/store/index.ph...products_id=30
It's up to you if you want an extra car or not.
Krio is offline
Old 05-31-2012 | 04:19 PM
  #15333
polarbear72's Avatar
Ok. Thx a lot guys. I was leaning towards just getting a new buggy. It seemed to make more sense
polarbear72 is offline
Old 05-31-2012 | 04:21 PM
  #15334
madweazl's Avatar
Originally Posted by chevmaro
Throttle would cut. Or my servo would stick turning and i would go in a circle. Sometimes it was just laggy. I had about 5-6 glitches in a 6 min race. It happened first and second race and then the third race of the night it was fine. Not sure what the deal is. I tried 2 different glitch buster caps one spektrum and a racers edge. I use the same setup on my other cars and they did not have a problem. While in the pits I left my buggy on with the hood off and noticed the green light on the futaba reciever would go RED and then my Tekin would restart itself, then the light goes green again. I suspect this is what it was doing while i was racing.
I dont mind adding a BEC if it is necessary. I'll try swapping in the savox servo first. I had been planning to do that anyway.
This typically shows up with the Tekin ESC, Savox servos, and Spektrum receivers, this is the first time I've heard of it with a Futaba receiver. I picked up a Savox servo because it was orange and matched the other anodized goodies on my Durango even though everything else I run has Hitec servos. I had the exact same issues you're having. Dropped one of the Hitecs in there and no issue.
Did this setup work properly for you in the past?
madweazl is offline
Old 05-31-2012 | 04:30 PM
  #15335
Has anyone tried the nano tech shorties in the b4 because i want a shorty just dont want to spen 80$ and not end up liking the feel of one and the nano tech is just 33$
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
chancejeff is offline
Old 05-31-2012 | 04:42 PM
  #15336
madweazl's Avatar
Havent tried them but I also couldnt find a setup I liked with the shorties and bought some more fullsize packs. Your results may very. For the record, I had the same results with the 22.
madweazl is offline
Old 05-31-2012 | 05:16 PM
  #15337
I see alot of people like them that do realy good with them so i just want to give it a try to see if i like it better
Old 05-31-2012 | 05:37 PM
  #15338
gamedog1966's Avatar
Ibhave had te same prob with a savox and specktrum reciever and dx3c radio went to glich buster and stopped the prob. Now I'm with a futaba 4pl and haven't had that prob just a bad reciever and then sent it in and they replaced it. But it do sound like u are getting brownouts and if the glitxh buster isn't helping then try another servo and if that fix the prob sell the old on. But firdt make sure that the ends are plugged n all the way in the reciever first and no wires are frayed, if they are u can place a dab of solder on the frayed are and then heat shrink that section a lil. Check all wired and the antenna it could have got frayed upon installation. I hope this is helpful to u man and good luck with ur troubleshooting and prob solving
gamedog1966 is offline
Old 05-31-2012 | 05:46 PM
  #15339
madweazl's Avatar
Damn, more to drink than I've had (and that isnt easy)!
madweazl is offline
Old 05-31-2012 | 06:04 PM
  #15340
JakeC351's Avatar
I've tried shorties and fullpacks and I liked the shorty alot better makes the car feel a lot more nimble and responsive and I could push it harder. The only downside I had was that it wasn't as good as handling the pot holes and bumps as a full pack.
JakeC351 is offline
Old 05-31-2012 | 07:44 PM
  #15341
CHIZZLE's Avatar
Lol, that shit's hard to read!
CHIZZLE is offline
Old 05-31-2012 | 08:45 PM
  #15342
RcRacer27mx's Avatar
Haha, kinda fun to try to read though.
RcRacer27mx is offline
Old 05-31-2012 | 09:09 PM
  #15343
Shaved U-Brace and C hub revisited!
Ok guys I've read most of the old posts on the shaved U-brace and "C" hub tower setup. For some it works and others it don't.
So wondering if anyone has tried using a shaved U-brace with a modified stock RTR hub?
What I did with my RTR B4.1 (cars my experimental for mods to my Worlds car, currently running a 6.5 motor) is I took the stock hub and drilled a hole for the ball stud about a 1/4 of an inch below the center hole, "C" hubs drop mounting holes 2mm. This puts the hole at the top corner of the rectangular indentation on the hub. Placed a washer and nut on the off side of the hub (indentation side) for support and stability for stud. One washer on the brace side.
Hooked it all up. At bones level the turnbuckles are almost level with the bones.
This B4.1 has been twitchy out of the box, no matter weight, tires, caster, camber ect! Always twitchy!
Done this mod and a totaly different car! Handles good and predictable, corners very well on power comming out of turns. And seems the mod is durable, has'nt worked loose or broke a hub yet!
Anyone with any thoughts on this or even tried this??
Tc3junky is offline
Old 06-01-2012 | 12:24 AM
  #15344
Eli's Avatar
Eli
Hobby people has new shortys out too that are very reasonable.
Eli is offline
Old 06-01-2012 | 04:48 AM
  #15345
Wildcat1971's Avatar
Tech Prophet
Why do ppl say the B4 is twitchy? The B3 was twitchy for sure. I always felt like the b4 was stable and predictable. To me anyways, maybe because I run stock though on a high bite track.
Wildcat1971 is offline
