SC10 Thread Part 2
#19
Avid springs.....http://www.avidrc.com/product/19/springs/
Avid uppers....http://www.avidrc.com/product/5/acce...ccesories.html
Or use the rings from the Traxxas uppers...http://www.amainhobbies.com/product_...rs-Upper-Lower
Losi bottoms....http://www.amainhobbies.com/product_...Cup-Set-TLR-22
#20
Speaking of Spring Cups, I just changed mine with the RPM lower Spring cups this car is now handling like a dream.
it seems the stockers were either flexing or the entire spring was not sitting on the Cup because its night and day difference.
Question in regards to weight/ballast?
I dont have the FT Ballast weight but I do have some fishing line weights that I want to distribute. Now do you guys run your battery to the fron or the the back of the chassis. Also where do you place the weights?
#21
#22
I run a standard b4 pad in the front of my pack. 3 ounces of weight under the battery foam behind the battery. 1/4 oz next to receiver. I want to try less weight in the truck and also a shorty pack. I only run 17.5 blinky (no esc timing).
#23
[/URL]
[/URL]
#24
Once they release that kit with the lowers as well I will be placing a massive order for..
12mm Springs
Spring Upper Cups
Spring Lower Cups
12mm Hex Adaptors F&R
SC10 Revolutions Bearing Set.
#25
I've got nearly every Avid product on its way for my SC10
Steering rack, A/C carbon hub upper, F/R Spring sets. The quality looks awesome and I look forward to running these products. I think I'm going to just stick to the 22 cups and Traxxas uppers for now. Not really digging the slip on spring retainers for some odd reason...
#29
24Likes
