SC10 4x4 Thread
Does anyone have any feedback on the Factory Team kit?
http://www.hobby-pros.com/Team-Assoc...eam-_p_19.html
I was thinking about getting it but I wanted to see what you guys though first.
I run the stock bearings until they need to replaced and then I use the Avid bearings. Super inexpensive (a big difference between cheap and inexpensive in my mind), and a great quality bearing. Typically I'll use the Revolutions for offroad everywhere except the clutch bell in my nitro cars and I'll use the metal shield in my onroad cars on carpet.
Would be very nice if someone with center-stick-pack-mod would post some pics and his setup.
The T-Bone-Bumpers are great, i had some for my 1/10 Buggy and they are very durable, i think for buggys and truggys they are even better then the RPM and look great. but i don't like the look of the ones for the SC10 4x4, but maybe i'll get one for the rear. with approx. 15-20 drivers on a small indoor track, there's a lot of "enemy contact". i thought about putting some spacers under the 4 screws, on wich the bumper is mounted, so the other SCs hit the bumper first and not the rear of the body, but that might cause some leverage force and break the bumper. The stock front bumper works great for me, it doesnt brake and slides good over the carpet if i don't land very well xD Maybe i'll put some LEDs there to make it look better.
http://www.rctech.net/forum/10340416-post17669.html
http://www.rctech.net/forum/9711364-post7854.html
http://www.rctech.net/forum/10409446-post18524.html
In addition to what it comes with, I personally would buy the Front Spring Kit as well and whatever is needed to do the 8mm mod.
i need help asap! frustrated to the max right now.. just installed a pro4 tekin motor 4600kv with a sxx tc spec. before i had a lrp 4.5 550 ( motor seemed to cog when going slow then full throttle.. switched over to the tekin.. smoother feel and more torque which i like.. but now there's this windy noise (sorry for my spelling) super annoying and it never used to be like that.. i checked my mesh it seemed right.. i just bought a new pinion too last week.. i cant imagine the spur making that sound.. when i get onto the straight at full throttle the car is silent.. only when going slow around corners its super loud!!!
any help would be greatly appreciated!
thank you
any help would be greatly appreciated! thank you
If you were 32p before, you got something going on that I'm not familiar with.
I believe that locks the front, not the rear.
There has been one person that has run it and he liked it. Better acceleration coming oit of a tight turn leading into a triple that he was not able to make before and now he is clearing it.
I would imagine that it will give you a lot more steering push, more than the 30k front diff fluid that many are running in the front diff.
Search it.
Search it.
I also run 2 stage pistons. V2 center diff. And a 5oz steel skid plate up front. Weight bias is 48% front 52% rear at 102oz RTR. Works well on our outdoor track.
If the FT kit was out when I bought mine I would have got it, I ended up getting the upgrade kit but of course it doesnt come with all the cool goodies like the ti turnbuckles and all the bling blue hardware.
Been running the center stick since last year. Truck feels quicker side to side and more stable. No concern about battery height. No weight needed for left to right balance. Can be tight if using a large esc. Finishing my spare chassis right now and it will be able to use center stick or saddle with no changes. Just drop in your battery of choice. I use 2mm carbon plate for the mod.
Got any pics of your setup? It would be nice to be able to run sticks or saddles, I'm guessing that with saddles it is an inline setup rather than side to side?
How much does your esc and rx weight? I weighed my electronics a few days ago and the left side will be round-about 80grams heavier than the right side. So i can move the batterie a bit to the right side, or add another 80grams to the chassis. But when i move it to the right, there won't be enough space for my esc (ezrun wp-sc8). I can also mount the batterie upside-down, so the mass-centre (i don't know how its exactly called in english) is higher, but more centered. A guy at our local track mounts his batteries in his rc8be also upside down to move the mass-centre more to the middle of the chassis.
@smr: so you removed that "fin" and had much flex? Do you use the FT chassis-brace which connects the front and rear chassis-parts?
5Likes
