RC10B4.1 FT/WC
Old 05-20-2012 | 05:56 PM
  #14971
1Fastpede's Avatar
yes.
1Fastpede is offline
Old 05-20-2012 | 06:06 PM
  #14972
Originally Posted by bilster44
28 or 29/72 should be just fine with the 13.5.
This gear combo was money today!! (29/72) Motor temp was at 140 after a 5 minute run plus a couple hot laps. Thanks again!!
nhraman is offline
Old 05-20-2012 | 06:11 PM
  #14973
Originally Posted by zipperfoot
I know its the wire because the same thing happened to me. It would spin fine with throttle holding it off the ground but as soon as i placed it on the ground it would cog. Another pro driver said it was the cable. So i checked it and found it had come loose. The same thing then happened to a buddy but his wire was bad. It looked fine, no damage, but with a new wire it ran fine. There is only one way to plug in the connector. Make sure you didnt force it in the wrong way. Why this happens, no idea.
It was the sensor wire it just wasn't plugged in enough on the esc. Thankyou and to think I thought it wasn't plugged in on the motor enough the whole night it turned out to be the opposite side that wasnt.
chancejeff is offline
Old 05-20-2012 | 06:29 PM
  #14974
Wildcat1971's Avatar
Tech Prophet
someone game me a pair of new alum b4 hubs the are .5 (each I assume). I was thinking of putting these on my buggy. I currently have the stock ones that come with the b4/sc10/t4. The plastic ones. They are 0 degree? And what would the .5 hubs do to my setup? more rear bite?
Wildcat1971 is offline
Old 05-20-2012 | 06:36 PM
  #14975
Motofan747's Avatar
Originally Posted by elex300
In order to use the BB springs I need the traxxas collars and 22 cups correct? I know other companies make these but in general this will work?
Yes they will work
Motofan747 is offline
Old 05-20-2012 | 06:47 PM
  #14976
madweazl's Avatar
The Traxxas lowers work fine and come with the uppers.
madweazl is offline
Old 05-20-2012 | 06:52 PM
  #14977
I bought a used B4.1 WC edition. Can someone give me all the part numbers to re-do the diff. I am confused as I think it is different than a normal B4, correct?
goin2drt is offline
Old 05-20-2012 | 07:13 PM
  #14978
easy e's Avatar
http://www.rctech.net/forum/r-c-item...ront-rear.html
easy e is offline
Old 05-20-2012 | 07:37 PM
  #14979
carver gt's Avatar
The part numbers should be on the back pages of your instruction manual.
carver gt is offline
Old 05-20-2012 | 08:04 PM
  #14980
RC*PHREAK's Avatar
34/72 a decent start point for 17.5 blinky?
RC*PHREAK is offline
Old 05-20-2012 | 08:22 PM
  #14981
mxracer458's Avatar
I run 72/31 on indoor clay
mxracer458 is offline
Old 05-20-2012 | 08:33 PM
  #14982
My manual is t4.1/b4.1 NOT WC version which I think are different part numbers.
goin2drt is offline
Old 05-20-2012 | 08:35 PM
  #14983
T-BirdJunkie's Avatar
The T/B4.1 FT uses the same exact diff as the WC.
T-BirdJunkie is offline
Old 05-20-2012 | 08:38 PM
  #14984
goin2drt is offline
Old 05-20-2012 | 08:39 PM
  #14985
socalrcer's Avatar
As long as your manual shows the Ball Diff, it is the same.
socalrcer is offline
