SC10 4x4 Thread
NO offense to WC but guys like him are VERY hard to get out of their box. He is very one sided and i dont see him all of a sudden saying "WOW was i wrong , the RCShox Cdif is much better than my VTS setup"!! Its not going to happen hence a waste of my time and his. Neutral minds are needed to test products along with racers that "want" to make it work instead of looking for ways to make it not work. Take Cameron for instance, A very good driver and is very neutral which is why i use him pretty much exclusively for testing because i know for a fact he will tell me the truth good or bad and by the time the general public gets my products they are RIGHT, hence the V2cdif. Had i released it based on my testing alone high grip racers would still not have enough punch, so you can thank him for that
the last two weeks before the release between Cam and I we tested 8 different spurs,8hole,10hole, multiple pin locations etc etc.
My products are not "snake oil" they actually work and do what they are suppose to do! No gimmicks just innovation, dont think for a second that i have not had team drivers test because i have and some of them do run my Garodisc WC just doesnt know that until now
Those of you that use the Garodisc know that there is NO situation where a stock pad will outperform them, and i am willing to put money on that!
the last two weeks before the release between Cam and I we tested 8 different spurs,8hole,10hole, multiple pin locations etc etc.My products are not "snake oil" they actually work and do what they are suppose to do! No gimmicks just innovation, dont think for a second that i have not had team drivers test because i have and some of them do run my Garodisc WC just doesnt know that until now
Those of you that use the Garodisc know that there is NO situation where a stock pad will outperform them, and i am willing to put money on that!I have a clutch basket in by parts box too so if I need it at WC track I will run it, but I won't know until I make it there. On my home track the v2 diff is faster than the slipper. Three other people's trucks that I have installed the v2 diff for them have gone faster.
I have mad respect for both them and what they can do with with an RC. No doubt they are dialed with AE's set-up.
v2 Center diff tech tip:
Some small screw drivers have a magnet on the end (normally cheep give a way ones with company logo's on them). Stand up the pin on the end of the magnet and slide it into the hole first. Slide the magnet off the pin sideways so not to pull the pin back out. Do the pin first and then the ball. When taking the diff apart a bigger magnet can be your friend sucking up all the pins and balls before sliding the gear off.
Lay a towel accross you lap then sand the truck on it's side with the diff up for easy install. If you drop something the towel will keep it from disapearing on the floor.
Now to figure out how to tune the thing...
It has been for 7 months, Only now people are finally realizing it after attacking me for saying these exact same things. I don't hold any ill will.
i noticed on AE's online set up sheets it has two boxes for the slipper, de-coupled and coupled. my set up sheet in the back of the book doesnt.
i know one disc drives the front and one for the rear but can someone explain to me what the difference in a coupled slipper vrs a decoupled slipper is.
thanks.
thanks.
thanks.
thanks.
Coupled means all the slipper plates are keyed to the rear top shaft giving equal power to the front and rear all the time. Stock setup is decoupled meaning the inner slipper plate which drives the belt to the front is not keyed to the rear top shaft and relies on the slipper pad to provide rotation.
thanks.
Oh ya, and it's far superior to the old pin mod due to it being factory parts ! Insert sarcasm
5Likes
