RC10T4.1 Thread.
#1307
how packed is the surface?
If the ifmar pins are something you feel may work, you may like the Flip outs better as they appear to be a lower tread Goosebump. For me at least, I liked the goose bumps when the track was a bit softer so they could bite more. Ifmar pins when it was too soft for a double dee / holeshot style tire that would load up.
#1308
Hey guys. I finally ran my T4.1ft at the track it was very pushy. I'm running box stock setup but I did switch to inline front axle it make the car more precise sharper offpower turning but on power the truck just pushes.I run a Gen aces 5300 30c lipo in the middle. I had a old t4 ft(carbon) and that box setup but it was running the proline m3 over the t4.1 jconcepts. The track is a hard pack clay indoor very little dust...I'm guessing blue groove but not sure. Had a blackish blue color and hard as concrete LOL.
#1309
Are we correct in assuming the tires being ran are the right ones up front for the surface?
I probably would first look at tires. Next, I probably would find a setup other than the box one on AEs site. Unfortunately, the out of the box setups I have personally never had the best luck with from AE.
#1311
okay that makes sense.
You will want a different tread pattern than those carvers.
I would ask around your track for the hot tire choice and buy those.
go here for setups:
http://www.teamassociated.com/cars_a...anuals_setups/
go here for setups:
#1312
edit: Here's a pic
#1313
What tires you guys running on indoor clay? When its high bite I use suburbs MC compound and they hookup great. But lately it has been dry and dusty and they are just not performing. Whats a better tire I can use for a dry dusty indoor clay track?
I might try 4 degree toe instead of the 3 degree I am currently running.
#1314
#1316
Been running the goosebumps in the rear, still looking for sugestions for the front. The ribs seem to push and slip to much!
#1317
#1319
Katana!....like John Belushi in the deli!,maybe I can do this....thanks for the confidence and the heads up on AE.
#1320
